Question about Kitchen Ranges
Fan works, but lights don't work. Kleenmaid model
Fan works but lights don't work. Kleenmaid model RH14 90cm rangehood.
  • 833 Answers
SOURCE: Fan Not Working
Sounds like a motor problem...but not necessarily. Cut power to the unit. Expose the motor assembly. Turn the fan by hand...if it is jammed or hard to turn...replace that motor. Not that? There is likely a motor connector. Get a test light at the hardware store. Disconnect the motor and then probe the wires coming to the connector from the power side (with the power on again) to see if the tester glows. Yes...bad motor. No, find the bad connection. It is possible that this unit uses a multi switch...if that's the case, there will be three wires coming out of it...One is power in...the others go to the light and the fan. Then, the switch will be the culprit. Hope this helps.
Posted on Dec 09, 2007
SOURCE: BABT83.2AL Canopy Rangehood The fan/suction is
These units have a history of fan failure due to inferior 220 volt Italian fan.
I have just had fan fail and retrofitted a ebmpapst blower fan model D2E146HT6702 which is readily available in Aus for around $120.
The fan speed control is by inverter variable output so you don't use all the speed select wires that this fan has. Connect the Red wire on the range hood to the Black on the motor (High speed winding) and the Black on the range hood to the Blue on the motor (Neutral) and the earth to the earth (Green).
Disconnect and toss the cap in the white enclosure under the PC board enclosure (the new fan has the cap on board). Don't know how easy to fit in the range hood as mine is in an acoustic fan housing in the roof (makes it wisper quiet when running)
Posted on Aug 16, 2008
SOURCE: service manual for rangehood
I asked a electician, it caused by start up capacitor fail.
Posted on Jan 14, 2010
  • 177 Answers
SOURCE: The lights on the under
could be a blown transformer to supply the correct power to the lights or a loose connection on the light holders.
Posted on Aug 23, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Hi I have a WRF600 rangehood.
Sorry to read about your problem, I hope this helps you out.
their are no fuses, check ckt braker
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 23, 2010
Why baumatic rangehood BABT83.2AL stop working
Remove the filters and see if you can see the fan blade. Try turning the fan blade by hand. If its jammed up or tight, you may need a new motor. If it spins freely, turn on the rangehood and give the fan blade a spin . BE CAREFULL when doing this, if the motor starts up and runs properly after spinning it, it could be the start capacitor has failed. If it still wont run or if the fan is tight, you may need a new motor. Spare Parts should be available. You will have to trawl the internet looking for Baumatic parts suppliers in your area.
Jun 27, 2014 | Kitchen Ranges
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
Kleenmaid rangehood
I found the manual for the Timex T 309T here:
http://www.manualowl.com/m/Timex/T309TT/Manual/272204
Oct 27, 2013 | Timex T309TT Clock Radio
Fan stopped working on our Bosch rangehood (Type D-FX41-8 or E-Nr. DKE935AAU). Lights working but the fan only inhibits a humming sound.
hi ;
the fan motor needs repair , the cause of humming is the vibration of induction on AC current in the motor.
if the motor stopped means it has faulty shafting and bushing, or maybe the starting capacitor needs a replacement, don't turn it on or use it to prevent burning of induction wire,
also it needs a qualified technician to repair ,
Sep 03, 2011 | Kitchen Ranges
The lights on the under side of the rangehood do not work .i have replace the bulbs ,the exhaust fan works ,is their a re set switch
Aug 23, 2010 | Ovens
Service manual for rangehood
Jan 14, 2010 | Frigidaire PLHV42P8CC Kitchen Hood
Looking for a manual for SMEG rangehood HACD60SS model bought in 2008. Rangehood may not be installed properly, it's not sucking up air into the hood.
check to be sure that the fan works, and if it does check to be sure that the air flow path to outdoors is not clogged. one way to do this is to remove the hood and slide a dry garden hose through the entire vent pipe to the outdoors.
Jun 29, 2009 | Kitchen Ranges
Rangehood malfunction
My Baumatic Rangehood model BAISL92.2 had the letter A flashing. I was advised by a repairman that it indicated the filters needed to be cleaned with warm soapy water. Apparently in my particular model there is a built in 30 hour timer for when the filters need to be cleaned. To remove the flashing letter A, I was advised to clean the filters, turn off the rangehood and while it was off, press the (-) (minus) button and hold for 5 seconds. It beeped and the flashing letter A was removed. This worked for my particular model - I couldn't guarantee it would be the solution for your model. I hope this is some help.
Jul 22, 2008 | Baumatic Upright Freezer BV12A
Broan allure fan and light
Check that you have not accidentaly switched the wall socket off in the cupboard above the rangehood. The slide switch could also be faulty.
Oct 30, 2007 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
