Watches Logo
Posted on Mar 31, 2008
Arnette Digital Watch
I have a Arnette Digital Watch and the Alarm is set and I cannot turn the alarm off.  Does anyone know how to do this.
  • Anonymous May 22, 2008
    I have the same problem..........
A
Anonymous
So My arnette digital wrist watch was going off every 5 minutes. I hit the Mode, Reset, and St/STP buttons at the same time out of frustration, and it seemed to turn my alarm off.
Instructions for a Seiko Alarm Chronograph Watch A158-5040A?
Question moved from Lands Phones category.
SEIKO - A158 5040
Digital Watch Library http://www.digitalwatchlibrary.com > DWL > seiko-a1...
SEIKO - A158 5040 - Digital. Released in 1978 Vintage Digital Watch - Brought to you courtesy of digital-watch.com.
SEIKO QUARTZ Cal. A159 Alarm Chronograph
My Retro Watches https://myretrowatches.co.uk > uploads > 2020/09
The A158 Alarm Chronograph model can be set to give a time signal ... QUARTZ. ALARM-CHRONOGRAPH. START/STOP. DATE/SELECT. STOP-ALARM. WATCH SET TIME SET LAP STOP ...
3 pages
Missing: 5040A ‎' Show results with: 5040A
Instruction ' Seiko Watch Corporation
SEIKO WATCH https://www.seikowatches.com > customerservice > ins...
Seiko is one of the few fully integrated watch manufactures. We design and develop our own movements using leading-edge technology.
1helpful
C9 champion digital alarm
Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
May 10, 2013 • Watches
5helpful
2answers
I accidentaly reset time & date on my square arnette watch and i need help to set it
Thank you for contacting FixYa.
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 • Watches
1helpful
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
I have an arnette digital watch, which beeps on the hour. I can't figure out how to switch this very annoying feature off! I can switch the alarm on and off by pressing the start/stop and reset buttons...
I have an Arnette watch as well and have long lost its manual. The model of my watch is AR 2201. Before it didn't beep, but after my move (where the watch must have been bouncing around a lot), it started to on the hour, EVERY HOUR. It has been driving me crazy. Hopefully this will help you, though the answer comes so late. For my watch, I pressed the ST/STP and RESET buttons (which both happen to be on the right side of the face) simultaneously. The watch beeped when I did this and I saw the little bell icon disappear! Good luck with yours.
Nov 22, 2009 • Watches
22helpful
Need to fix time on Casio G-Shock
The hands are set independent from the digital display
Setting CASIO G-Shock Watch
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
28helpful
2answers
Adh1583
go to mode and scroll to select alarm setting.Look at the display of your watch if you see the icon of the bell there,it means its alarm hourly,if you off the alarm the bell icon of the display will gone,so it will not alarm..
hope this may help;
don't forget to rate;
Sector adv 1000 setting alarm
key for setting time can be pulled fully (to set time) or shortly (only 0.5-1 mm) for setting alarm. then you should turn it and watch how it moves (automatic, without your turning). when it comes to desired time just push key in. the watch will automatically rewind to present time and it will re-start running.
Apr 14, 2008 • Watches
5helpful
2answers
I dont know how to set the time and date on my watch{arnette model ar 2041}
do you have the button on your watch named "el" its the top left one, press and hold it for 3 secs. after you can change the time. you can press the mode button to change it :)
Jan 15, 2008 • Watches
8helpful
5answers
Unwanted alarm
using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
