Question about Minolta magicolor 2400W Laser Printer
The error light stays on - Minolta magicolor 2400W Laser Printer
This is a problem with this printer. On mine it was because the pin on the right side did not fully contact the switch when the cover was closed. To remedy the problem I took a phillps screw driver and loosed the housing that has the pin molded into it. I then folded up a piece of paper many times and wedged it under the housing and walla the error message was fixed.
Posted on Sep 08, 2010
The airbag light stays on in my 2007 Prius. What can I do.
Have the SRS system scanned to find out what the error is and correct it. It is a stand alone system that does a self check every time the key i turned on. If the system comes back all clear, the light goes off and the system activates. If there is an error, the light stays lit and the system remains disabled.
Apr 25, 2018 | 2007 Toyota Prius
Tip
Flashing Light Error on Tasimo Coffeemaker
That blinking error light! I still could not fix it with the other solutions.
I cleaned it, refilled it, and nothing worked.
Here is what I have done that made it work.
There is a floating magnet in the water reservoir. When it drops down,
the error light is SUPPOSED to come on.
I found by jamming a scrap piece of clean plastic in the magnet cavity on the water side of the magnet. This forces the magnet to stay in the up position AND against the sensor contained in the machine itself. NOW the error STAYS OFF. Hurray! So far, it works!
Note: You must monitor the water level under this new circumstance because the error light will not come on even if the water level drops down.
RW
on Sep 28, 2010 | Braun Tassimo Coffee Maker
Engine light staying on
Try tightening the gas cap. If this doesn't fix the problem you need to take it to a mechanic or dealer that can read the error code that is causing the light to stay on.
Mar 27, 2014 | 1996 Nissan Quest
Engine light came on last night. Checked all fluids. all okay. Light went off while driving down the highway and has stayed off. Road conditions when the light came on were icy and wet. Highway conditions...
This may or may not be a problem. The error code will be held in the copmputer, so the next step is to pull the error code(s)... However, if the light stays off, perhaps something hiccuped, and you need not investigate....
Feb 13, 2011 | 2005 Chrysler Pacifica
Not printing and all the error lights stay on
You probably need to replace the toner. Check your manual , it should advise what to do when certain lights are displayed.
Nov 11, 2009 | OKI C5100n Laser Printer
C43 stylus does'nt print while red and green lights stay on
If the light are flashing, it mean waste ink full. You must clean waste ink pad, and reset the counter. You can use SSC, find at indoreset.blogspot.com. But,.. you said the light are on. try to resinstall driver. after printer recognised by comp, check status monitor. Green light on is power on, and red on mean chip error/ink out error/cartridge error.
May 29, 2009 | Epson Stylus C43SX InkJet Printer
After replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Apr 02, 2009 | Dell 1710 Laser Printer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Error light stay on
probably needs a new printhead. try switching with a good if know a friend with bjc 50/80/80. all are compatible.
Nov 27, 2007 | Canon BJC 80 InkJet Printer
Minolta magicolor 2400W Laser Printer Logo
191 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
