Question about Whirlpool Calypso GVW9959K Top Load Washer
Buzzing sound wont spin out - Whirlpool Calypso GVW9959K Top Load Washer
  • Whirlpool Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinebuzzing sound wont spin out - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 17, 2010
5 Suggested Answers
  • 108 Answers
SOURCE: WON'T SPIN DRY
You need to check if there is power to the motor. If so the motor is defective.If not, the timer may be the problem. There should be a wiring diagram on the back of the unit. Using a voltmeter, trace the power.
Ray
Posted on Dec 17, 2008
  • 3 Answers
SOURCE: LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Posted on Mar 15, 2009
Karthik316
  • 187 Answers
SOURCE: Buzzing/Ratcheting sound while drying
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Posted on May 22, 2009
  • 109 Answers
SOURCE: series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Posted on Jun 16, 2009
Wont do anything
See if the buzzing is coming from the timer, it may be broken. Try to change the timer to spin and see if the motor works.
Dec 02, 2013 | Maytag MTW5700TQ Top Load Washer
My unit isnt blowing .i can hear just a buzzing noise. ive tripped both of the breakers.still nothing.
if you here a buzzing sound, then its getting electricity. buy the sound of it the fan is bound up. it probably needs oiled. if fan will not spin and you here a buzzing sound its bound up, from dust and grime have a good day !
Jun 28, 2011 | Heating & Cooling
Buzzing Noise on my Ps2 Slim
It sounds like your power supply has become faulty.
Feb 06, 2010 | Sony PlayStation 2 Limited Edition -...
When ignition is switched on their is a whirring sound and engine wont turn over.and start.
It sound like the lobes on the starter's shaft have worn down and aren't making positive contact with the flywheel anymore. A "whirring sound" would be the starter motor spinning but not "catching". If it's a clicky/buzzing sound then it would more likely be the starter solenoid, low battery/bad alternator.
The "whirring" sound should still be winding down for just a second after you turn the key off. The "buzzing" symptom will stop instantly when you turn the key off.
Dec 02, 2009 | 2002 Jaguar X-Type
Won't start
you have a bad solenoid battery or starter try to ground the starter touch positive to groundwith a rubber ended screw driver if the starter spins you have a bad solenoid
Jun 22, 2009 | 2003 Yamaha YZ 250 F
Series 70 fills wit water stops then makes a slight buzzing sound
Jun 16, 2009 | Kenmore Washing Machines
Water wont spin out but hear buzzing sound
The water pump is spinning but not pumping it out change the water pump.
May 12, 2009 | Washing Machines
Buzzing at my cell phone near the flexible
remove the battery... and dont return it so that the buzzing wont come back....
Feb 27, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Whirlpool Calypso GVW9959K Top Load Washer Logo
184 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
