Question about Video Game Consoles & Games
I am missing parts.
I have a New Bright Harley Davidson fat boy remote controllled motorcycle. I am missing the 9.6 volt battery pack and charger and the door on the bottom covering the battery.(battery compartment). Can you tell me where to get these parts and the owners manual????
Sale me transmitter of HD
Posted on Mar 12, 2011
2003 Harley Davidson FLSTF Fat Boy no spark
Hi, William and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Tilt sensor needs a reset.
11. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Harley Davidson Forums
Harley Davidson Softail Workshop Service Repair Manual 2000 2005 $7 cheap
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/harley-davidson-softail-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Aug 07, 2017 | 2003 Harley Davidson FLSTF Fat boy
Why are my Harley Fat Boy rpm's unstable with Caltex petrol at sea level?
Hi, Eric and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system, carburetor and/or filter.
12. Old dead or bad fuel.
13. Fuel tank vent system plugged or carburetor vent line closed off.
14. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
15. Carburetor controls misadjusted.
16. Damaged carburetor.
17. Incorrect valve timing.
18. Weak or broken valve springs.
19. Damaged intake or exhaust valve.
20. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
2015 2017 Harley Davidson Fat Boy Fat Boy Lo Fat Boy
Harley Davidson Manuals Mark Workshop
http://partsfinder.onlinemicrofiche.com/stcharlesharleydavidson/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm
How 6ya Works 6ya A must have !!! Totally "FREE"
Dec 29, 2016 | Harley Davidson FLSTF - FLSTFI Fat Boy...
How do I put new battery in 2007 fat boy
Hi, Patricia for this scenario you will need your service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Need help replacing 06 fatboy battery Harley Davidson Forums
Motorcycle Repair How to Replace Battery on Harley Davidson Motorcycle
http://www.carlsalter.com/pdfs/Harley%20Davidson%20Softail%20Service%20Manual%202007.pdf
Dec 04, 2016 | 2007 Harley Davidson FLSTF Softail Fat Boy
2006 Harley Davidson FLSTF Fat Boy alarm will not disarm
Hi, Tyler for this scenario you will need your service, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere $8 you can download another one.
How to Arm Disarm Factory Alarm
Harley Davidson Softail Workshop Service Repair Manual 2006 $8 http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2006-harley-davidson-owners-manuals
Mar 28, 2015 | 2006 Harley Davidson FLSTF Fat Boy
How to replace 9 volt alarm battery on 2001 fatboy
If your'e referring to the back up battery in the alarm itself.
I have a 2012 Fat Boy, and my alarm is not a Harley item, but is mounted in the stock Harley location. It is between the rear wheel mud guard and the battery box. The rear wheel must be loosened, and lowered or removed, then the mud guard loosened or removed. You can see some of my alarm when looking at the bike from the clutch handle side, just behind the battery location. Some parts might be apparent there, but not accessable unless you do the above. I had mine professionally installed cause the rear tire looked like a task I'd rather pay for to have removed. I needed a new tire anyway, so the overall service cost was lower having them both done at the same time.
PS Harley will not install an alarm that's not a Harley brand.
I hope this helps. Good luck
May 27, 2014 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
Charging battery dead
No, you can charge it in place.
In fact, a "battery tender" is a good idea:
http://www.ebay.com/itm/BATTERY-TENDER-12-Volt-Trickle-Charger-CAR-BOAT-ATV-12V-Junior-Jr-Motorcycle-/231110566640?pt=Motors_Car_Truck_Parts_Accessories&hash=item35cf4362f0&vxp=mtr
The "pig-tail" on the right of the pic is installed to the battery posts, the the charger plugs into the other end that you have mounted remotely in an accessible area.
Dec 20, 2013 | 2011 Harley Davidson FLSTFB Fat Boy Lo
Replace battery on 07 FLSTTI fat boy
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 11, 2013 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
2007 Fat Boy cranks but won't start
Hi Robert, and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jul 04, 2013 | 2003 Harley Davidson FLSTF Fat boy
How do i hook up battery charger to my 2000 fat boy? is there a way without taking off the seat?
You can connect the positive clamp of your battery charger to the starter connection. The positive cable of the battery connects to the starter solenoid. Then the other side of the solenoid connects to the starter motor. Connect the positive clamp of the charger to the connection where the battery cable connects to the solenoid. Connect the negative clamp to the engine or frame.
Good Luck
Steve
May 30, 2011 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
I am missing parts.
search the manufacturer
Mar 25, 2010 | Toys
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
