Question about Rheem 30 GAL ELEC SHORT Water Heater 6YR SC 82SV302
Sounds like a squirrel inside water heater
Just moved into 5 year old home. Has Rheem everkleen 30 gal electric hot water heater. Frequently making sounds like a squirrel is inside the tank. Today I drained the tank and still have the sound. Any ideas how to get rid of the noise?
  • 349 Answers
Check your thremostat setting if it is set to highest position it may be causing some of the noise over heating the water and making the noise. And you can put an insulated jacket on it to maybe help with sound.
Posted on May 17, 2010
Rheem serial R0996B30824 Model 7130S in MFG Home 40 gal how old and why does hot water run out after one shower . Just bought modular home need help
If the water heater is electric; BE SURE AND TURN OFF THE CIRCUIT BREAKER TO THE WATER HEATER, DOUBLE CHECK THE VOLTAGE AT THE WATER HEATER WITH A MULTIMETER BEFORE DOING ANYTHING ELSE!
Here's a good video on how to test the heating elements.
To check the reset button.
To check the thermostat.
Nov 27, 2016 | Rheem Water Heaters
How do you set tempature to make the water stay hotter longer? I have a Rheem 82v66 2 (65 gal) and cant fill my bath tub with out running out of hot water.
65 gallon water heater should fill more than 1 bathtub since typical bath only uses 12-14 gallons hot water. First hour delivery on your tank should be greater than 60 gallons.
http://waterheatertimer.org/Hot-water-use-chart.html
Since you have such a small amount of hot water, it sounds like bottom element is burned out, or one of the thermostats is bad. There are two thermostats, and two 4500 Watt elements on 65 gallon tank.
If upper element was burned out, or water heater was not getting 240V electricity, then you would have NO hot water. So we know upper element is good and circuit is good.
Ordinary tank-type electric water heater is fully repairable by homeowner and parts are available at hardware or home center.
I suggest taking 30 minutes and doing troubleshoot before replacing any parts.
Buy cheap multimeter from home center.
When testing voltage, rotate multimeter dial to 240-250-277 VAC
When testing elements or continuity, rotate dial to Ohms.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help. I can answer questions as you fix the water heater.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on heater.
Jan 11, 2011 | Rheem 65 GAL ELEC Water Heater 6YR Self...
I have a 135 litre, 10 year old Rheen mains pressu...
usually on the hot water piping, It starts to rust closed faster than the cold side, due to electrolosis. What you r discribing are the first signs of this happening. only solution is to replace the effected pipes..
May 20, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
I am afraid that you have burned the heating element out or an inline fuse is burned out
May 15, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
The noise is inherent in electric hot water heaters. It is the noise that the water makes when it is being heated by electric heating elements. Mineral buildup on the elements can make it worse, so changing the elements can help...but will not totally elimenate the noise. When I install a new tank and turn it on all I have to do is listen to it to see if it is working or not...even brand new will make a sound...it is the sound of hot water... :-)
heatman101
Mar 25, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
We just relocaed a modual home with a Rheem electric 40 gal warrior hot water heater, we have no idea of previous care, in setting up the home and trying to get hot water, after turning the water on,...
sounds like the element is burned out....probably got turned on before it was completely full of water. You can get a kit that has new elements and upper and lower thermostat in it. Those are the only things that can go wrong with an electric water heater....other then leaks.
Oct 28, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Oct 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Electric Water Heater Using Too Much Electric.
Maybe you want to think about getting a tankless heater.The gad unit works real good.But the electric water heater i want to think you should check the thermostate.Maybe it is struck and not cutting off every time.
Mar 13, 2009 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Rheem 30 GAL ELEC SHORT Water Heater 6YR SC 82SV302 Logo
203 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
