Rca 52 in rear projection... start up menu always on
New RCA 52in rear projection tv... seems to work fine but every time I shut it off, when I turn it back on the start up menu always come on first-- (a blue screen that starts off with english or french choice ect. ect.). I need to press "clear" on the remote to get out of the start up menu every time I turn on the TV. Really annoying. What can I do? Thanks
how do you change a conversion chip on my RCA projection tv P60923BL..the tv picture squeeses up in the middle of the screen
  • ozzyron Apr 02, 2008
    thank you i plugged my tv into the wall instead of plugging it into my cable boxand now it comes on without the menu..Good job ..Thanks
    Sergeant:
  • 247 Answers
The setup menu will repeat until it is completed and/or something is hooked up.
On my TV it kept reoccurring until I connected up the wire from the roof antenna, even though I had cable already installed.
Check your manual for setup instructions or if you do not have one, Google the make, model number and "owners manual" to see one online.
Hope this helps. :)
Posted on Mar 31, 2008
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button light turns on and the tv makes a short whistle sound, this happens...
Not sure why chat got closed/ disconnected.
There is big transistor TL010 attached with heat sink near flyback transformer, this is horizontal output transistor, check it and replace if found shorted.
Thanks.
Apr 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Screen dont work
proabably it,s because you left it on for long time , or the image power saver is wrecked and damaged after a storng lightinning , and if you have cleaned ther tv screen with a wet wiper it causes that to happen
May 11, 2008 | RCA P52937 52" Rear Projection Television
Rear projection tv broke
try resoldering the vertical output IC. This is a common problem the tubes blank out but sound and on screen displays still work 90% of the time its the solder connections on the vertical IC that causes it.
Mar 24, 2008 | RCA P52960 52" Rear Projection Television
finich seting up ...go through the setup menu. and pushing ok instead of clear. if it continue this indicate the main ac is being interupted.. do you unplug it at night? or just power it down.
Dec 15, 2007 | RCA HD52W58 52" TV
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
