Question about GE JBP69 Electric Kitchen Range
Range top won't heat
Light comes on when you turn stove top on but doesn't heat. Oven will only come on when range top light is on
    Novelist:
  • 184 Answers
CHECK YOUR HOUSEHOLD WIRING TO BE SURE YOU HAVE 240VOLTS BETWEEN THE RED AND BLACK WIRES OF THE OUTLET. CHECK THE CONNECTION WHERE THE POWER CORD IS ATTACHED TO THE RANGE. IT SOUNDS
LIKE A FAULT IN THE POWER BEING SUPPLIED TO THE RANGE.
Posted on Mar 31, 2008
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
Broiler burns but the bottom burner on the stove will not come on the glow igniter turns orange but the burner doesn't light also one eye doesn't light, the striker sparks but the burner...
FOR THE OVEN NOT HEATING
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
FOR THE SURFACE BURNER NOT LIGHTING The holes on the burner espically those around where the electrode are dirty/clogged. By using a paper clip/safety pin to push in and clear the holes then clean the burner up with some steel wool the burner should light. GENE
Aug 29, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
Stove top or oven doesn't heats. range type is a accubake system
Have you check the outlet to see if its geting power, if not, check the main breaker in the breaker box, you may have to turn the breaker to the off postion and then back to the on postion, if power is going to the outlet your stove should work.
Feb 12, 2010 | Kitchen Ranges
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Frigidaire electric range oven and top burners wont come on
It sounds like you only have one side of the 220v current coming into the range. I suggest checking the outlet feeding the range for proper power. The problem could actually be in your circuit breaker, only sending power via one of the conductors.
Mar 11, 2009 | Electrolux 30" Self-Cleaning Freestanding...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
GE JBP69 Electric Kitchen Range Logo
85 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
