Question about Mitsubishi WS-65807 65" Rear Projection Television
Can you easily seperate the top and bottom of the ws 65807 for moving?
    Problem Solver:
  • 12 Answers
Yes. I have the ws-65809, which is virtually the same model. There are 4 rubber plugs that come out on the sides of the TV. under these are four screws. WARNING! You must disconnect the wires connected to the screen before removing the screen or removing the top half of the TV. If you don't the wires will rip out. I believe they disconnect with 2 clips.
Posted on May 16, 2010
Add hdmi port to mitsubishi ws-65807
I doubt it as it was never designed for that kind of input, Component works best on this set and it should have only one HD input for a box marked in the menu as DTV.
Dec 13, 2012 | Mitsubishi WS-65807 65" Rear Projection...
Need to dis assemble a ws-65807 tv to move
go here and sign up for a 7 day use ($5) and download the service manual (and schematics and pcb layouts) for your tv
http://www.free-service-manuals.com/members/
Jan 19, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Can you easily seperate the top and bottom of the WS 65807 for moving?
Yes, There are four screws on the sides in big holes under black plastic caps, and then 3-4 screws on the front behind the speaker grill. Check to see if the rear cover will need to be removed too - I don't remember... Take the screen (Fresnel) assembly off first and then the whole top section comes right off. The top weighs the most out of all the parts.
Mar 25, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Lines in the video.
My friend , this is technician job. If you are one well, replace capacitors in vertical and check for bad connection.
Sep 13, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Model WS-65807
Reset the covergence to factory specs from the remote. Do it three times
Aug 10, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws-65807
I suggest to visit the website of manufacture to have both question answered . thanks
Apr 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65807 and blue-ray compatibility
that tv set is only good enough to receive a 1080i signal at the DTV INPUT. unless you can change the output of the blue ray it will be outputting 1080p
Mar 01, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws 65807 RED CRT
What I usually find on sets like that is that there is a loose solder joint on the CRT board itslef. You must get to the bottom of the picture tubes, pull off the CRT board from the red CRT and examine all solder joints on that board. Chances are one or more will be cracked, and resoldering all joints on the board should clear up your problem.
Aug 04, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Relocating tv
Yes, this set does come apart for moving. Remove the lower screw from each side of the TV back. On both sides, pull off the two plastic caps and remove the two exposed screw. Lift the cabinet top straight up until the guide pins clear the holes in the bottom cabinet. Be careful and don't drop anything.
May 03, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
144 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
