I have a Syntax K7 SV400 motherboard. The board will post but will not install the os. The bios recognizes the cd drive and the hard drive. When I try to install Windows 2000 Pro the cd drive spins and I get the message to hit any key to boot from cd. Then the system fails to read the cd. I have tried several different cd drives hard drives processors and memory sticks to no avail. Also when I change the jumpers from 100 mhz to 133 mhz or 166 mhz the system will not post. What is wrong with this board?
  • 721 Answers
Nothing, first try the disk in a working pc & see if it auto-runs in windows,if it does then try a different ribbon cable on the cd drive. If it doesn't then the disk is dirty or damaged. Also, not accusing you but windows 2000 is probably the most burned copy of windows around. If this is the case, go to whoever you got the disk from & tell them to re-burn it at 4x if possible but no faster than 6x, then the disk will work. As far as the bus speed is concerned(the jumpers), if the processor is a 100mhz, that's all the faster it will operate. Especially on older pentiums,which it sounds like you have. Now the processors will go to a slower speed, like 166 to 100. Keep in mind when switching cpu's you must set the jumper to the matching or slower speed or it will not post. Also, that speed is half what the actual clock is, meaning, 100 is 200,133 is 266, & 166 is 333 mhz. So if it's a socket 7 or 380 board, you can run an AMD or Cyrix cpu instead of the pentium & use whatever speed you'ld like because AMD products back then didn't lock the multipliers. Also on those older boards, some won't run certain ram speeds, like if the board has 100mhz ram it may not like 133 much. Ram wasn't very backward compatible back then.
Posted on May 17, 2010
Can not boot from dvd/cd
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
Dec 30, 2010 | Syntax SV400 Motherboard
My hp compac come on powers up, but will not go on line, will not recognize the disc drive , will not recognize any USB ports and when I go to shut down, it will sit on the "shutting down" screen for...
just a mobo huh, no PC, there.
so what PC did it come out of???? HP what? desktop .
turns on, ok
will not recognize the disk, (what disk? what drive, what disk,??)
floppy, PATA HDD, SATA HDD, or CD drive.?
will not recognize, USB ports. (in BIOS or in Tne OS)
what OS, windows 3.1? what/? what Operating System??????
what OS will not shut down, and installed by whom and what media>?
take this unstated PC and install the OS, as it came new.
This PC is so old its not supported by HP, now.
so find and install disk (media) and re-Install the OS.
Fresh.
there it is, Google fails to find the match to any HP PC model name.
HP has zero data on it, now, its too old.
Jul 13, 2017 | HP (D7580-60003) Motherboard
My computer with Syntax SV400 mother board will boot sometimes, sometimes will not do an automatic reboot when loading drivers and sometimes nothing happens when I turn the power on
you should check if the driver's are working properly in device manager if not try this program in free to download instal,scan and update your drivers.
Nov 25, 2009 | Syntax SV400 Motherboard
Not make instal xp new hard drive "seagate baracuda 7200.12 ST3500418AS, and my motherboard dont see hard for instal
It seems you are saying that the board will not see the new hd.
You need the instructions for the hard drive and the mother board to install the SATA drive.
Some motherboards may need to have the bios upgraded, if it can.
Others are too old.
Sep 26, 2009 | Asrock K7 Upgrade 880 Motherboard
Hey,im looking for the same bios for Syntax SV400.
hi
try to download the drivers from this link,
http://members.driverguide.com/driver/detail.php?driverid=350127
you have to register first before you can download.. it's free..
May 09, 2009 | Syntax SV400 Motherboard
Old motherboard and Vista (audio and RJ-45 on the board)
www.driverguide.com,
You need to register and download any driver you wish.
Apr 02, 2009 | Syntax SV400 Motherboard
Bois problems????
No - this is something that can generally only be resolved with a repair install of the XP.
The repair option can be accessed while doing a standard (i.e. boot from the CD) install. Note: this is a repair option after you select to install; not the repair/recovery options on the first screen.
It should detect your OS and ask if you want to repair it. This will cause you to have to reactivate windows, and I highly recommend having your drivers already downloaded and ready to be installed. Some programs my have to be reinstalled also.
There is a sysprep tool that can be used, but I've always found it easiest to do a repair.
May 07, 2008 | Syntax SV400 Motherboard
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
