Question about Marantz PMD580 Voice Recorder
My Marantz PMD580 does not archive recordings. I shared a folder on my pc and I have the ip address but it doesnt work. Are there any troubleshooting steps I can try. Help!!!!
2 Suggested Answers
AlanKinNA
  • 110 Answers
SOURCE: My Marantz PMD580 does not archive recordings. I
I'd call the dealer for support. This piece of equipment is quite detailed and potentially complicated.
Yes, I'd sure call the dealer, if you have one.
Otherwise, try reading the manual, at ...
http://www.d-mpro.com/users/getdownload.asp?DownloadID=402
Alan
Posted on Mar 24, 2010
How do I unlock the device to be able to record a file? When we hit the record button the screen tells us to unlock. Only the Record Pause and Stop buttons will work.
Hi Johnna, here is the manual for it, I had a quick look and didn't see a pin to unlock it you could try 1234 or 0000 good luck with it. Cheers_Greg.
http://www.solidstatesound.co.uk/pdf/PMD580um_eng.pdf
May 13, 2015 | Marantz PMD580 Voice Recorder
How do i connect two pc together
If they are alrady on te same router / WiFi, make a drive or folder 'shared' and then on the other use 'Map network drive'
If not, then just use any old Ethernet cable to link them (both PC's should be happy enough to set a default IP addresses and 'see' each other) - modern PC's don't need special 'switch over' cables (a 5m Ethernet cable from the £1 shop will work fine)
On the PC you want to 'expose' data, you 'Share' the folder (right click for the folder 'properties', look for 'security/sharing' etc).
On the other you 'map network drive' (if asked for a user name/log-in, use the account on the OTHER PC ..)
Apr 04, 2014 | Dell Dimension 8300 PC Desktop
I am using server 2003 as file server wchich is in workgroup and connected to the network. problem is arising when any system from the network wants to access the shared folder the user unable to access...
Try this:
go to start>run and type: \\ server ip address
for example, if its 192.168.10.20, type \\192.168.10.20
Navigate to that shared folder, right click on it and create shortcut.
If the previous step doesnt work, go to server, unshare that folder, restart and share it again. Try accessing it.
Hope this helps
Aug 11, 2010 | Microsoft Computers & Internet
My Marantz PMD580 does not archive recordings. I shared a folder on my pc, and I have the IP address but it doesnt work. Are there any troubleshooting steps I can try. HELP!!!!
Alan
Mar 24, 2010 | Marantz PMD580 Voice Recorder
Konica Minolta Bizhub 350
You are getting a failure sheet. This happens when the scan doesnt go through. I think you are reffering to SMB scanning, which needs to have the following setup on both the MFP and the copier.
Host ID or NAME - IP address or hostname with DNS resolution.
Share Name - This is your SMB share name or folder share name on the remote PC
User Name - This is an account that is configured on the remote PC
Password - This is the password for the account setup on the remote PC.
Some things to keep in mind: Third party firewalls can block the bizhub from writing files.
Set share permissions to full control. (under sharing tab> permissions buttion)
Set NTFS permissions to at least write access. (if you have a "security" tab on the shared folder.
Or, you may see something like "allow network users to change my files" on the sharing tab. This basically does the same under different configuration scenario.
One last thing. If you havent changed anything since the problem started, it is probably just something like an expired password on the account that is setup for the copier.
Good Luck.
Jun 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How to connect my phillips freeline LS1300 series desktop to my laptop?
If you are trying to connect the desktop to the laptop just so you can access each computer from each, you will have to setup a 'local area network' on each.
You first have to check the hardware. Both computers should be connected to a router or to each other via ethernet cable. Make sure connections are secure.
To confirm if there is physical connection, get the ip address of each computer.
1. Go to Start>run. Type in "cmd" without the quotes. Hit ok.
2. In the command prompt, type in "ipconfig". take note of the ip address for each. If it starts with 169, that means there's is no physical connection. Check your cabling or tell me, how you have it setup. Otherwise, you're good.
Second, setup the software. I am assuming, both computers run on Windows XP.
Do this on each computer.
1. Go to control panel. Go to "network and internet connections".
2. Click on 'Network Setup Wizard' on the left pane.
Check these screenshots.
http://screenshots.leeindy.com/network_setup_wizard.shtml
Follow the screenshots and do the following.
Take note of the computer name that you will enter for each computer. You must make sure that the Workgroup Name is the same for both computers. It doesnt matter what name you enter or if you leave the default as long as both computers have the same workgroup name.
Now, that you have connected them, you have to create a portal for each computer to access the other.
1. Go to computer1. Right click on a blank area on your desktop wallpaper. Left click on new>shortcut. type in \(ip address of computer 2. it should look like something like this ---> \192.168.1.3
Put the computer name of computer2 in the shortcut name box.
Try to open it. It should open the shared folders in computer2.
Repeat this process on computer2, entering the ip address and name of computer1 this time.
This will let you access the folders stored on each computer from the other. Be sure to share the folder you want to access remotely.
If you want to access 'my documents' in computer1 from the other computer, Go to computer1, right click 'my documents' and click sharing. check the box to enable sharing.
Do the same thing on any folder you want to share on the originating computer.
Oct 03, 2008 | Computers & Internet
I am trying to set a network using a wired desktop and a wireless laptop (desktop using XP and laptop using Vista)I am using a Linksys WRT160N, I can get on the internet with no issues at all but when...
in the router's lan (not wan) configuration - set the dhcp server (gateway address) to be 10.1.10.1. Then set the addresses of the clients (connected to the router) to be assigned addresses from 10.1.10.10 - 10.1.10.20. Set the desktop's TCP/IP address to be 10.1.10.11 (static) with a subnet of 255.255.255.0, and a gateway address of 10.1.10.1. Set the laptop's wireless connection (TCP/IP adapter) to have a static 10.1.10.12 address with same subnet mask and gateway address of desktop. Change the workgroup on both computers to be of the same name (case sensitive here) to a name such as HOMENETWORK. Then on each computer, open up "My Computer" and right click on folders, files or printers that you want to share on your network!
Sep 26, 2008 | Computers & Internet
Marantz PMD580 Voice Recorder Logo
267 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
