Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
My husqvarna sewing machine has started sewing by itself when I plug it in and turn it on. I can't stop it sewing by itself. How do I stop this I've checked all buttons and plugs
Hi all. I inherited a 6440 with this issue. The problem is a blown capacitor. The simple, but not entirely "right" solution is to remove it. If you take off the motor case housing you will see the motor/foot pedal wiring area to the right of the motor (facing from the rear of the machine). There are 4 screws holding wires and the capacitor. The lower two screws hold the capacitor which is brownish-silver in color. Just back off the screws and pull it out; tighten the screws after removing. Mine was ruptured and I've seen the same image here: http://jim-linda.blogspot.com/2011/08/viking-husqvarna-model-6440-sewing.html Again, removing this capacitor solves the issue, but to fix it "right" go to RadioShack and get a .1uF/250V capacitor and install it the same way you removed the old one. The RadioShack part # is 272-1053. It's online listing is here: http://www.radioshack.com/product/index.jsp?productId=2102589
Posted on Jun 04, 2013
  • Kenmore Master
  • 7,365 Answers
Does the foot pedal plug into the machine by itself? if so unplug the foot pedal & then turn on the machine, if it doesn't run by it's self then you know it's the foot pedal.
but if it still has the problem check the foot pedal for a circuit board
Posted on Jul 29, 2010
My Viking Husqvarna 6440 has also developed this problem. Cannot stop it running except by pulling the plug. Sorry I cannot offer a solution.
Posted on Jun 28, 2010
  • 201 Answers
What model is your machine? If it is a computerized model with a Start/Stop button, I would check to be sure that button is not permanently depressed. The next thing I would do is check the food pedal - it may be stuck in a position that makes it run straight away when the power is turned on (maybe a small bit of "stuff" is stuck down the side between the pedal and the part that sits on the floor???).
I think also that some of the upper end machines might have settings for disabled persons and maybe yours has this facility turned on?
Posted on Jun 22, 2010
My husqvarna rose is sewing without me! I am doing something and suddenly it starts sewing straight and does not stop till i turn the power off
You probably need to have that checked. Until then, be sure to always unplug the machine when you are finished--don't want to start sewing while you are away from the house.
Mar 30, 2017 | Husqvarna Sewing Machines
Husqvarna sewing machine freezes and stops sewing
Is it a mechanical machine or computerized? If mechanical, it could need a good cleaning and oiling. Mechanical machines need to be oiled, and if not, the old oil solidifies and prevents the mechanical parts from moving.
Mar 15, 2015 | Husqvarna Sewing Machines
Husqvarna #1 sewing machine powers on, then cuts off
Can you turn the handwheel without a great deal of effort? If so, it sounds to me like your motor may be drawing excessive current and the machine is shutting off so as not to burn out the circuits.
Feb 16, 2014 | Husqvarna Sewing Machines
Husqvarna 3500 keeps runing
your foot petal rheostat is broken you need a new foot petal
Jan 17, 2010 | Husqvarna Viking 1
Husqvarna Sewing Machine starts sewing when power switched on
The problem is probably the foot control. The little wires wrapped around the insulator have broken and are shorting against each other or the cord itself has a short. You can purchase an aftermarket foot control at your local shop, this is the cheapest way to try first, if that does not correct the problem replace the cord.
Jun 29, 2009 | Husqvarna Sewing Machines
Buttonholes
Put on the C foot. Select the buttonhole stitch. The machine will start sewing in the bottom left corner of the the buttonhole. Sew the length that you need, press and release the reverse button and sew the right side of the buttonhole. When you get back to the bottom, press and release the reverse button again and the buttonhole will be finished and the thread will tie off and the machine will stop. If the buttonhole is what you want, press and release the Stop button and the machine will repeat this buttonhole as many times as you need until the machine is turned off or the Stop is pressed again. When repeating, you need not press the reverse. Just press down on the foot control and continue until the machine stops by itself.
If you don't like the first one, just sew another one using the reverse button to set the ends.
Jun 28, 2008 | Husqvarna Viking 1
Power won't stop - Husqvarna/Viking 3600
your foot controller is damaged and should be replaced.
Jun 02, 2008 | Husqvarna Viking 1
Foot pedal dead, machine keeps sewing!
There is no suppressor in the foot control of a 425. Only the control unit, which may need to be replaced. If the machine accelerates to full speed, it may have a problem with the "stop right" board which tells the machine whether to stop with the needle up.
You could have several problems, so go see a qualified Husqvarna repairman. You may contact Husqvarna customer service to locate the best one in your area.
Mar 12, 2008 | Husqvarna Freesia 425
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
298 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
