Question about Refrigerators
I am looking to replace my Whirlpool Model ED25SMXLNRO. The problem is I only have 68 1/2 inches max and your new models seem to be 68 7/8". Is there a solution. This refrigerator wooked for 24 years and my wife does not want a french door if possible, all though they would fit.
  • 109 Answers
Keep looking, there are many options still.
Posted on Mar 31, 2008
Wiring diagram for His Master's Voice model 68-55
Here is the circuit you are looking for {:o) Kevin has an amazing collection of vintage and veteran radio service data available free
http://www.kevinchant.com/uploads/7/1/0/8/7108231/hmv_model_68-55_circuit-1.pdf
Nov 29, 2013 | Radio Communications
I have a Whirlpool front loader Model GHW9150PW1.The drum seems to be wobbling real bad and dragging the bottom of the washer,can you help.
First, remove the 2 screws that hold the bottom front kick-plate on and remove the plate. Look to see if any of the shocks have come loose or broke. Post back your results.
Jan 20, 2013 | Whirlpool Washing Machines
My whirlpool Gr2 microven Model # GH6177-XPS does not heat. All display functions seem operable otherwise.
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if you unit has power, and things lite. it is more likely you have a control/switch problem,
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
dsddd
Dec 23, 2010 | Whirlpool GH6177XPS Microwave Oven
I replaced the serpentine belt on my 2002 accura rsx type s it sqeaks and seems loose is there any way to tighten it....tks
The tentioner should keep the belt at the right tention. Are you sure its the belt? I had some squeaking in my 05' RSX and replaced the Tentioner Pulley and the squeaking went away. Maybe this could be the same case. Hope this helps.
May 10, 2010 | 2003 Acura RSX
Only works on full down/up force
Remove the cover from the motor unit and check the drive gear. This is sometimes an indication of a gear that is going bad. Your opener is around 20 years old and just maybe you should look at the new safer models.
Apr 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am rebuilding a Winchester Model 68 22 caliber and am looking for a manual or exploded view on line. It came in pieces but all seems to be in order.
Gunparts.com ,, They have exploded views of every rifle in their shop. Some rifles, they don't have parts for, they won't have a picture of.
Jan 16, 2010 | Weaver Optics
Ice maker not working
i know it may sound crazy but what i do is buy a whole new kit for the box and pull the whole icemaker out and replace it. you will have lots of salvageable parts left over for the future. the reason i do this is a couple of parts will cost you as much as a whole new kit and guarantee you fix the part thats broken, the spare parts left over come in handy now and then, the new kit itself will have a warranty, the parts wont. it is lots quicker and easier to replace the whole maker than to take it apart and guess which thingy is at fault. i told you it was crazy sounding but hey, i'm a pro and this is what i do. mine was 68 dollars for two parts and 110 for the whole new kit. good luck
Dec 07, 2008 | Whirlpool ED2NHGXM Side by Side...
Washer does not spin or agitate
you need to remove the cabinet to expose the washer. once you do that you need to remove the 2 clips that hold the pump to the motor. then remove the 2 1/4 inch screws that hold the 2 clips onto the motor. ( remove the wireing connector first) remove the motor and Im sure you will find that the coupling need to be replaced. There are 3 parts to the coupling. 1 rubber and 2 white plastic parts. replace the coupling and install everything in reverst. your washer should work fine after this.
Jul 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
