Question about Dryers
Kenmore dryer 500 , model # 110.79522800 .
Kenmore dryer 500 model # 110.79522800 . Electric igniter turns on and off while dryer is running.
  • 16 Answers
SOURCE: model 110 86574120 how old?
its from 1985 first and third #s after the 110
Posted on Jun 27, 2009
  • 56 Answers
SOURCE: Kenmore dryer 110 708 12990 Igniter glows, but
replace the two coils on the gas valve use the maytag coil kit much cheaper and same part
Posted on Jun 30, 2009
localwonder
  • 6784 Answers
SOURCE: 29'' Kenmore electric dryer series 110 not heating up
Check the following to address this issue.(Most common issue will be a burned out thermal fuse.)
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Aug 03, 2009
marka19
  • 1430 Answers
SOURCE: I have a kenmore gas dryer, model 110-9644190. It
For a free video on diagnosing this go to www.appliancehelponline.com/servicemanual.html
could be thermal fuse,thermostat,dryer coils,ignitor
Posted on Feb 26, 2010
  • 2180 Answers
SOURCE: kenmore dryer 500 , model # 110.79522800 .
does the flame lite?the ignitor should come on and then the flame lites and will stay on until the dryer reaches the right temp. then it shuts off,if the flame isn't liting no gas is coming in,bad gas coils will do this or the gas valve,most likely it's the coils located on top of the valve,take out the two phillips screws,remove the cover and change out the coils
Posted on Mar 25, 2010
76712 Kenmore...is there a pilot light?
What is the full model number of the dryer? The Kenmore 11076712693 dryer has an glow bar igniter (electric igniter) and no pilot light. The parts diagram for the burner assembly for this dryer is available here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11076712693/0582/0151200/10052613/00001?blt=06&prst=&shdMod= .
Please add a comment with the full model number of your dryer if you would like more assistance.
Dec 02, 2012 | Dryers
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
I have a kenmore 500 series gas dryer that will not ignite and heat up can you help?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 29, 2011 | Kenmore 500 6952 Dryer
Kenmore series 500 gas dryer not heating up. model # 77542600 Other than the ignitor what could be the problem?
Check the coils on gas valve. If igniter glows bright & no CLICK sound heard after a few seconds of igniter glowing, coils are bad, or flame sensor if so equiped
Feb 13, 2011 | Kenmore 500 6952 Dryer
My Kenmore 500 series electric dryer seems to be heating, but just stopped running. I hit the start button, and the drum heated up, but did not start turning. I'm guessing that the start switch is not...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 14, 2010 | Kenmore Elite HE4 Electric Dryer
I bought kenmore 500 washing machine dryer,
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 30, 2010 | Kenmore 62602 Electric Dryer
Kenmore dryer 500 , model # 110.79522800 . electric igniter turns on and off while dryer is running.
Mar 24, 2010 | Kenmore Dryers
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Kenmore dryer 500 electric, will not turn on, circuit breaker ok
Sounds like a broken belt or a faulty motor...
Sep 22, 2009 | Kenmore Dryers
Dryers Logo
202 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
