TV not working properly
When TV is On there is sound but no image, only a horizontal line in the middle of the screen. What could it be?
    Sergeant:
  • 247 Answers
You have a vertical problem. See if there are any vertical (height or linearity) controls to adjust. Often there will be screws or knobs on the back.
Otherwise, it could be bad transistor or component in the vertical-deflection circuitry.
Hope this helps. :)
Posted on Mar 31, 2008
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
We have perfect sound but only a thin horizontal line in the middle of the screen.
this is a capacitor that has gone bad in the vertical delfection stage of the tv. it is an very easy and cheap fix if you know someone who knows how to solder and replace electronic components. If not then you'll just have to get another tv as taking it into a tv repair shop is not worth the cost. You could get another tv for what they will charge you to repair it,
May 31, 2009 | Sanyo AVM-3659S 36" TV
TV lose image, but it has sound
you have cold solder on vertical IC.
solder all crack contact IC legs
Mar 20, 2009 | Panasonic PVQ-2512 25 in. TV/VCR Combo
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
Jan 09, 2008 | Televison & Video
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
Thin Horizontal line through tv blank screen.
Replaced vertical IC ( la78041 ??>.. Or La78040 ). Look for born resistor beside IC. Replaced capacitor 100uf 35V too!!! Good luck !!
Nov 08, 2007 | Insignia NS- 27" TV27 TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
