Question about Sanyo PLC-XP55 Multimedia Projector
Sanyo PLC-XP55 lamp is good - but does not recognize input
Sanyo PLC-XP55 lamp is good - shows blue screen logo on powerup but goes to blank screen since it does not see the input from the vga port connected to computer. The vga port is outputting a signal but projector does not recognize it. It begins counting down the power off timer since it sees no input. Power off and unplug projector sometimes causes things to work again. Is this a controller board problem?
  • 4 Answers
SOURCE: sanyo plc-xu35
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be gone and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Posted on Oct 02, 2007
Fusiondc
  • 47 Answers
SOURCE: USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
Posted on Jan 17, 2008
SOURCE: Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Posted on Jul 07, 2008
robgarcom
SOURCE: Sanyo PLC-XU58 projector completly dead
I had the same problem and the technician diagnosed as being caused by a faulty Ballast which he said caused the bulb to fail. He didn't test the bulb but his experience indicates that even if the bulb was not blown it would have been stressed and it would only be a short time before it fails completely.
When these fail there is no real reason for it it seems but it has been suggested that a probable cause could be not cleaning the filter, at least every six months. The result of a dirty filter would be overheating and this could be the cause of the failure.
Posted on Oct 12, 2008
SOURCE: sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on.
Posted on Jun 03, 2009
Sanyo plc xu 22e,i get the red lamp indicator and the ready inicator but then the fans turn off and nothing happens. i can see the lcd through the lens and it displays sanyo and starts to count down from...
1,the lamp and the ballast is ok
2,it seems the motherboard is broken.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jul 30, 2011 | Sanyo FOR PLC-XE31
Sanyo PLC-XU33 multimedia projector. Starts up, goes through countdown, stays on for a minuit after that, then bulb goes out and it goes into shutdown?????? Rob,
hi,
check the video inputs. if there is no video input then the projector will goes off after count down.
also check that is the lamp replace light lights up or not. if its lights then you have to change the lamp and then reset the lamp hour.
ok
Jan 19, 2011 | Sanyo PLC XU33 Multimedia Projector
Sanyo PLC XU48 Need to know the lamp hours!
press and hold down the power button for about 20 seconds. The info will show in the top right of the screen.
Micketec
May 25, 2010 | Sanyo PLC XU48 Multimedia Projector
Projetor sanyo plc xp55, starts uplights up and then shuts down, what can be the problem? the indicators blinks showing warning temperature regards Edwine.
Check if you can see any dust clogging the outlets- use a brush and vacumm cleaner to clean every air vent around the case. there should be a few. There is usually a user replaceable air filter on one of the vents- un clip it and vaccum both sides of it. If it is too dirty clean it with soap and water squeeze it out and leave it to dry before re-installing. Projectors generate a lot of heat and conversely they are very sensetive to blocked air vents.
Hope this helps
Good Luck!
Jan 15, 2010 | Sanyo PLC-XP55L Multimedia Projector
How do i replace the lamp
remove the lamp door, remove the old lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 15, 2009 | Sanyo PLC-XP55 Multimedia Projector
I just replaced the lamp on my Sanyo PLC-XP55 projector and reset the lamp counter but now it won't turn on. When I press the power button, it goes into a cooling mode for 90 seconds and then never turns...
did you get the bulb from sanyo, or from another company that sells aftermarket bulbs? some of those are cheaply made and malfunction shortly after if they work at all. find your reciept, take it back and get a new one.
Jul 22, 2009 | Sanyo PLC-XP55 Multimedia Projector
Image not seen on screen...only a blue background
go into the settings menu and select the computer input.
Jul 17, 2009 | Sanyo PLC XU35 Multimedia Projector
Sanyo plc-su50 projector - can't get it to work
Please select correct input in menu of projector, that is Computer/ PC, like that...
Aug 02, 2008 | Sanyo PLC-SU50 Multimedia Projector
COLOUR
you have to buy a new lamp. i think it`s lmp 14 from sanyo. we have the same plc xr 70 and if you are interestet, we have two lamps and one of them you could have for a special price.
Nov 27, 2007 | Televison & Video
59 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
