Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
MTS2000.....Does my radio trunk?
I have a mts2000 flashport model # h01uch6pw1bn. The flash code is 0000040000006. Does this radio have trunking abilities? I have a friend who has a radiio with the same model number and its trunking.......Is mine?
  • 47 Answers
Trunking
Yes it does
Posted on May 26, 2008
SOURCE:
I need to know the channel my motorola mts2000 flashport is operating on
This type of radio can only be read out by someone with a software subscription and appropriate equipment. This could be an online or local Motorola dealer, a large company, or a municipality.
Best regards.
Dec 11, 2013 | Motorola HT1000, MTS2000, MTX8000/9000...
MTS non trunking made into a trunking system
Trunking radios are controlled by logging on to a central control - for use unless you have a trunking network with repeaters set up (costs a lot of money) stick to the non trunking versions - they can be reprogrammed to your frequencies and are very useable. without connection to a trunking network the Trunk versions would be better used as a door stop as they are very limited for re-use
Apr 30, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
How to create my own layouts?
Both the MTX8000 B5 & B7 models are Type II Trunking. If you are (un)lucky enough you might find an F3 modem that does Type II.
If it is an MTX8000 and has a front mounted display with either a 6 button or full keypad, you have a radio that will do Type II.
There were a few B3's that were Type II produced by Motorola. However, you can clone a Type II code plug into a B3 radio and it will work just fine.
You can run system watch using a MTS2000 handheld. Firmware version has to be above 5.44 (which has a 512k controller in it). Most MTS2000/MTX8000's only have a 256k controller, which will not work. You can put the radio into RF modem mode from the F4-F4-F4 (Trunking Config).
NOTE: When the radio is in the RF MODEM mode, it will do a self test and then the screen will go blank. The radio DOES NOT have to be programed to the system you want to watch. You set SYSTEMWATCH to the Spectra with RIB mode (works best). Even watches Type I systems.
If you have the accessory adapter for the side connector on the radio, the typical schematic of the speaker mic looks like this.
If you are using a Public Safety speaker mic with the radio, you might want to order part number 3205514W01 to cover the antenna connector on the radio.
If you are trying to program a MTX-838, from what we've heard, you need to use the MTSX software. The RVN4097F ver R02.10.01 RSS package specifically shows it programs the following radios: MT/MTS2000 MTX838/8000/9000. Now, the update for this software is RVN4097M R06.00.00 05 Sept 97, which should mean that it should program the radio as well. The cable you need is the standard MTSX programming cable.
Do you want to build your own programming cable? If you don't want to use an old speaker mic cable, see the individual part numbers of the parts for the Service Cable, below.
You may want to look at the schematic for the RKN4035D Service Cable. This is the actual Motorola cable used for programming and servicing these radios.
The individual part numbers for the components of this cable are listed below.
jedisvcpt.gif Reference Part Number Description C1 21-84008H06 Capacitor, 33nF 1 09-84538E03 Receptacle, 25pos 2 15-80349B36 Housing, Connector 3 30-05118W01 Cable, 13 Conductor 4 01-80754A26 Plug Assembly 5 42-10217A24 Strap, Tie 6 38-80373B24 Protective Cap 7 04-10058B12 Washer, Nylon 8 42-05184R05 Strain Relief 9 22-05541V01 Pin, Latch 10 41-05538V01 Spring, Latch 11 55-05536V01 Latch 12 15-05691W08 Housing, Connector 13 32-05533V01 Seal, Baseplate 14 32-05472P11 Gasket, "o" Ring 15 64-05241X01 Baseplate 16 39-05895V04 Contact, (13)
Mar 02, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
How do i program my motorola mts 2000 flashport scanner
Your Motorola MTS2000 is not a scanner but a high-end two-way radio. It requires a computer, special interface box (called a RIB, for Radio Interface Box), the proper cable from the radio to the RIB, and the programming software called RSS (Radio Service Software.)
This is much more difficult than a scanner to program and if not done properly can cause the radio to automatically transmit on frequencies that you are not authorized to use.
Try calling your local Motorola dealer and ask them if they will program it for you for receiving only. They will either flatly refuse or they will be happy to charge you a service fee. Some places are more willing than others.
Dec 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
About mts2000 i
The MTS2000 is a dealer programmable radio, there is no way to know what is in channel 4. You would need to have the radio read-out by a dealer, the print-out from the original programming or know who the dealer was and call them.
Jun 10, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola mts 2000
MTS2000 software will operate on Win98 and possibly XP, depending on the revision number you have. Yes, you can clone if the model number is the same. It will clone the entire codeplug of the radio. (Note: you will not have 2 same serial numbers. These are unique to the individual radio.)
Aug 16, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
How do I set a channel to scan
Take your radio to your local Motorola dealer for reprogramming. Usually the capacity of a scan zone is 16 channels. I am not certain on this radio without doing some research. Your local dealer will be able to help.
Jul 16, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Programming
Why buy a radio you cant program? I suggest you google for Motorola authorized radio shops in your area. Unless you have the software and equipment to do it, you won't be able to. You will also need letters of authorization for any channels you wish to have programed for transmit. If your a HAM or GMRS user be sure to bring a copy of your licence.
Sep 21, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
196 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
