Question about Air Tools & Compressors
I NEED TO REWIRE A DOERR LR22132 ELECTRIC
I need to rewire A doerr LR22132 electric motorits 5 hp rpm 3450 230 volts I5.0 amp to A sears air compressor(original equipment)
Can I rewire my 220 compressor to 110 ?
The short answer is: No. The longer answer is, the motor and controls were designed to run on 220 Volts, and as such cannot simply be re-wired for 110 Volts. You basically have 3 options: 1) Have a licensed electrician wire in a 220V circuit to your shop/garage/shed for the compressor. 2) Change out the motor for one designed for 110V (finding one that will work could be difficult, and might require modification of mounts, spindles, gears etc and probably not worth the trouble...but technically possible) 3)purchase a step UP transformer which can turn 110V North American household current into 220V.
Sep 13, 2014 | Air Tools & Compressors
Have an old (1977) Sears 2 hp, 20 gallon air compressor. It is wired for 230 volts. Is it possible to rewire it for 115 volts ?
you'd have to change the voltage regulator, which is usually inside the motor - on newer motors, if they have a separate Power Supply, you can sometimes change it on a slide switch... keep in mind, that 230 is MUCH more effective for a device made for drawing a lot of power - that motor might draw 8-10 amps at 220, which will be 2x that if you go to 110... so, when all is said and done, it might work out cheaper to just spend like $200 and buy a new 110 unit that is similar... but again, depends what you want to use it for...
I nedd diagram for electic motor doerr LR22132
I am sorry but we have no wiring diagrams here at fixya.
Jul 27, 2012 | Cars & Trucks
The green should be connected to the chassis, it is ground.
There should be a wiring diagram on it to tell you how to do this, but if not:
There may be T-leads on the motor labeled
P1, P2, T3,T4,T5,T8
P1-L1(black wire)
P2-cap/tape don't use.
T2,T3, and T5 wire nut together
T4,T-8 wire nut together with L2(white)
The power leads will be coming from your switch box on the compressor body itself. Don't wire the 220v directly to the motor, you replace the leads where the first motor was connected on the cutoff switch. There will be only 2 leading from the switch to the motor.
Mar 24, 2010 | Plumbing
I need to convert my 220 wiring back to 110 on my sears air compressor model number 106.173841 with doerr electric motor model 600678.
There should be a plate where the ires run thru, and on the plate or motor itself, there should be a diagram shouwing what terminals to connect the leads too.
Hope this helps.
Jan 17, 2010 | Air Tools & Compressors
I have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great, paul
i have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great,
Nov 20, 2009 | Kitchen Appliances - Others
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single...
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Aug 26, 2009 | Air Tools & Compressors
I have a electric dryer but dont have the outlet forthe plug
You don't need to 'rewire the house'. You will need a 240 volt circuit ran for the dryer to work though.
Jul 09, 2009 | Dryers
Air Tools & Compressors Logo
316 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
