Question about HP LaserJet 4345mfp Printer
Where is the maintenance kit on hplaserjet 4345mfp
I already added a new toner but it is telling me to replace the maintenance kit which I don't know where it is?
  • 17 Answers
The maintenance kit usually consists of a fuser which is on the left side just below where the paper comes out, a roller, which is on the right side inside of the manual feed tray, and about 6 new paper feed rollers, which are in the paper tray at the bottom.
the HP model is Q5998A, and they'll run you around $275 for an HP branded one. It has complete instructions on how to replace the parts with the maintenance kit.
Posted on May 27, 2010
2 Suggested Answers
  • 313 Answers
SOURCE: where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
configuration page or a supplies-status page
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Posted on Mar 25, 2010
I've tried to reset the maintenance-kit counter with this procedure but had no success 1 Turn the MFP off and then on. 2 When the memory count appears on the control-panel display, press and hold 6...
You can try to go in the service menu.
You can find this in the administration menu, go all the way down and you will see "service".
You need to insert the service code : 11434506
From there you can reset the maintenance count i guess.
Apr 21, 2017 | HP LaserJet 4345mfp Printer
What should i do, my printer is requesting me to replace document feeder kit and i dont know what to do. help me out please. MIKE
Never mind, I noticed the model in the subject. Sorry, it is Monday morning. Ideally you need to order a new ADF Maintenance Kit and replace the parts in it to maintain optimal performance of your printer. It comes with a pickup roller, separation pad, mylar sheet and instructions. After you replace the kit, or if you just want to reset the message and ignore it for another 90k copies, do this:
1) Turn the machine off and back on. 2) When XXXMB appears on the control panel display, press and hold the 6 button until all three LEDs flash once and then stay on. (This could take about 20 secs to happen) 3) Release the 6 button and then press the 3 button twice. 4) Press the 6 button to select NEW DOCUMENT FEEDER KIT.
After doing this, the MFP will complete its initialization sequence and the counter will be automatically reset.
The part number for the maintenance kit is: Q5997A, Amazon has it for about $91
Hopefully that helps.
Feb 21, 2011 | HP LaserJet 4345mfp Printer
Replaced toner and maintenance kit -keep getting yellow lights on exclamation and toner
If the toner and the exclamation lights are blinking yellow after replacing the toner and maintenance kit, then you will need to reset the photoconductor counter. But if the exclamation and the toner lights are steady on yellow, then that means there is something wrong with the toner.
Jul 27, 2010 | Lexmark E260dn Laser Printer
MESSAGE
Mar 24, 2010 | HP LaserJet 4345mfp Printer
HP4345 MFP printer and the print quality is fuzzy. I put in a new toner cartridge and that didn't work and i also created a cleaning page and that didn't help. what next? just had the tech out here last...
Fuzzy print is mostly related to 3 items in your printer. 1 the toner cart. 2 fuser. 3 transfer roller. A fuser replacement is a normal fix for this problem. Check your PM kit status by printing a supplies status page. A PM kit will have a fuser, transfer roller and feed rollers. If the PM level is low ,order and replace kit. If not you may want to get a new fuser
Sep 23, 2009 | HP LaserJet 4345mfp Printer
HP 4345. Need to reset the Maintenance kit error. How do I get into ther Service Mode and how do I reset it? Thanks!
Jun 08, 2009 | HP LaserJet 4345mfp Printer
Instructions for Hp 4345 mfp Maintenance Kit Install
the instructions are included in the maintenance kit
Apr 06, 2009 | HP LaserJet 4345mfp All-In-One Printer
Replaced maintenance kit - Now large black line
From what you've said it really doesn't sound like the maint kit would cause the problem. The fuser will cause ghosting or repetitive defects or smearing of the print the transfer roller also repetitive usually.
I think you have a toner (thats the easy test) or a laser scanner issue.
Try a new or known good toner cart. Did you change about the same time you did the kit?
If that doesn't work you can swap back the parts you removed when you changed the kit. One at a time, just the fuser and the transfer roll the feed rolls have nothing to do with what you describe.
If you still have the problem it is likely the laser/scanner assm.
You should proprably call a tech.
Hope this helps
Mar 30, 2009 | HP LaserJet 4250dtn Printer
Ho to refill Cannon Imageclass X25 toner?
You're only asking for problems trying to do it yourself. It' extremely messy, and more involved than simply adding new toner. and the refill kits are a scam. Find a reliable supplier, and get a remanufactured unit with a guarantee, if you're looking to save money. Cartridges are designed to go 1 cycle, and then require a new drum, cleaning blade, doctor blade, bushings, toner, etc. The cartridge includes not only the toner supply unit, but also a waste section, that, even if you were to refill somewhat successfully, the section will begin to overflow, causing further problems. Cut your losses.
If you're local. I can help:
http://www.hotfrog.ca/Companies/Sandman-Sales-Service
Jan 18, 2009 | Canon X25 Toner Cartridge for imageCLASS...
Replacement of the maintenance kit
I need more info or service program for reset sistem infomation (replace maintenance kit) on front panel,
Jan 17, 2008 | Ricoh Aficio AP600N Laser Printer
HP LaserJet 4345mfp Printer Logo
147 people viewed this question
Seeker5211
Seeker5211
