Cd x-9 teac will load cd spin but not play lcd reading says 'no cd'
    President:
  • 1,851 Answers
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn’t solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 16, 2010
Is the CD player replaceable if we can get the correct CD replacement? I've tried to get the info from TEAC and they don't answer my email.
See if you can get the exact unit on the cheap on ebay. Teac obviously does not give a rat's a-- about your dilemma .
Your laser assembly is fubar and not repairable - not cost effective.
Time to move on after 9 years of use.
Aug 02, 2015 | Teac Audio Players & Recorders
I have a teac x-9, and during cd play, the cd doors randomly open and close causing me to restart cd play all over again. it does this on its own, and i don't push any buttons for it to occur. is this...
clean your eject button or check it 2 see if it is broke. if u have a remote try 2 play a cd with the cd player with the batterys out of the remote. last 1. the cd door could be off trak witch wood make the cd off balance when the eye goes 2 read the data on the disk it misses its data an will cause your cd player 2 open.
Mar 15, 2011 | Teac Audio Players & Recorders
Teac PD-1200 Compact Multi Disc Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
Jul 04, 2008 | Teac CD-P1120 CD Player
I works mechanically, but doesn't play the CD
try cleaning the lens first use a lint free swab and GENTLY clean the lens. don't use any liquid on this. if that doesn't work then load a disc and gently spin the disc when it lifts into load posistion. if begins to spin on it's own then replace the spindel motor. if it still does not spin, replace the optical pickup, the EF sensors inside the pickup no longer have the ability to read (see) the disc.
Feb 03, 2008 | Teac PD-D2380 5-Disc CD Changer
TEAc HMX-760 "CD Drawer" was removed
you lost the cd tray timing,caused by force- eject,so you need proper alignment,you,needs specialist.
Feb 05, 2007 | Teac DC-D2831 CD Shelf System
TEAC MC-D95
weak or exhausted optical lens or laser assemly,needs replacement or adjustment,see a doctor.
Jan 18, 2007 | Teac MC-D95 CD Shelf System
75 people viewed this question
 Grubhead
Grubhead
