Question about Proform 6.5q Treadmill Walking Belt
The belt keeps going to one side+ rubbing,, is there anyone that
The belt keeps going to one side+ rubbing im in leeds how can i get it fixed at home
    President:
  • Proform Master
  • 832 Answers
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes.
Posted on May 18, 2010
Mower belt keeps coming off put on NEW John Deere belt same thing happens
Rub a bar of bath soap on the sides of the belt, this will help keep it in the groove of the pulley until the belt gets adjusted to where it is running.
Jun 08, 2017 | John Deere Garden
RNS 510 has stopped working
did u fix this problem as im experiencing the same
Jul 07, 2012 | GPS
I have a 2002 Ford Escort i replaced the alternator fine, then had to replace the serpentine belt yesterday i got the new belt and took the old one off. When i put the new belt on it started up fine no...
No the belt should should not rub on anything. Go to a ford dealership and ask the parts counter guy for a diagram of the belt routing they should print you off a copy no problem. all the ones i go to are happy to assist
Oct 01, 2011 | Cars & Trucks
The belt keeps moving towards the left side of the treadmill and rubs the side. How can I adjust the belt to fix the problem? It is a Weslo Cadence SR12 model. Thanks!
There are Allen bolts on both sides of the bottom on the front (away from the console) of the treadmill. Turn one one way and the other the other way to adjust the belt. If this does not work, your belt is probably worn and stretched and needs to be replaced. See Treadmill Parts to order a new one.
Aug 29, 2011 | Cadence Weslo 825 Treadmill Walking Belt
I have a troy bilt riding lawn mower and I followed the diagram on replacing the deck belt and it seems to keep rubbing something and burning the belt to smithereens. this has happened twice. have a brand...
Depending on which side of the belt is being rubbed is where I looked. If it is rubbing on the inside, I would suspect one of the blade being bound up and not turning.
If it is on the outside I would suspect something to do with the shield.
Jun 17, 2011 | Kitchen Ranges
It makes a rattling noise when i turn on and it keeps going on when im driving. People toll me it could be the A/C Compressor.How can i fix it myself?
Actually, any belt driven accessory could be the cause of the rattling noise, A/C compressor being one of them.
Maybe try to remove the belt, and then spin and check for side to side play of each of the pulleys.
The bearings in one of the turnable pulleys may be going bad.
Nov 03, 2010 | 1996 Hyundai Sonata
On my Sears ProForm 730 treadmill, I cannot make the belt move to the right (it is rubbing on the left side) by turning the left-side back belt screw clockwise (in any amount). The belt is walking back...
The belt does not need to be replaced more than likely. The problem is probably because that adjustment bolt is stripped out causing it loosen and keeping it over on that side. ProForm sells star washers that help them stay steady and not slip out. I would call them and ask for a couple of star washers and a new adjustment bolt for that left side.
Aug 16, 2010 | Proform 730 Folding Treadmill Model...
Rotation noise from rear end while riding
If the rubbing sound you have does not have a metalic sound to it then try rubbing a bar of soap on the inner side of the drive belt. Sometimes we keep our rides too clean and remove the natural lube in this area causing a sound as you describe
Jul 20, 2010 | 2008 Victory Vegas Low
there should be adjustment screws on the rear roller.
only adjust one of them (usually the left) if the belt rubs on the left turn the screw clockwise 1/4 turn and if the belt rubs on the right turn counterclockwise. Make small adjustments until the belt stays in the center
Mar 24, 2010 | Proform 6.5q Treadmill Walking Belt
My 05 road king drive belt is worn on one side. when looking down at the belt from inner side edge towards the center it is worn 1/4 inch across like the belt is rubbing on something. I'll replace the belt...
Has the bike been lowered? If so, this decreases the clearance at the top side of the belt where it goes behind the inner primary cover. Also there may be a belt guard rubbing somewhere. Remove the belt guards and use a flashlight to look for something rubbing.
When you replace the belt, you'll be able to see anything that might be rubbing the belt. Usually there is a noise associated with something rubbing the belt. If you hear a noise, determine what the bike is doing when you hear it. Is it going up or down after hitting a bump or something? Do you only hear the noise when you've got a passenger on the bike?
Sep 30, 2009 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Proform 6.5q Treadmill Walking Belt Logo
197 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
