When I put paper to shred ,all I get is motor noise but no shred
When I put paper to shred all I get is motor noise but no shredding
  • 86 Answers
You probably have a stripped drive gear. let me know what brand shredder you have.
Posted on May 17, 2010
  • ycorgigirl Jun 19, 2011
    I am not the original poster but i have this same problem. I have a staples SPL-826X. Can I do anything?
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
When I put paper to shred ,all I get is motor noise but no shredding
Take top cover off and check...normally plastic gears will be stripped ,cracked or broken.
Mar 24, 2010 | Office Equipment & Supplies
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Shredder makes a horrible sound when shredding.
Just put a lightweight shredder oil on some paper and shred the paper...do this a number of times this will get the oil down into the cutting shafts.
May 01, 2009 | Royal VF1000MX Shredder
Shredder is making a noise, but is not shredding when I put paper in.
Look into the machine as you try and shredding a single sheet of paper. Are the cutters rotating? If not then it could be that your machine has a damaged drive gear. The motor will still spin but will not have gear teeth to engage. It's time to call a tech in.
If they are turning, you may have something blocking the paper path.
Apr 21, 2009 | Office Equipment & Supplies
Shrededer motor remains on after shredding is complete
Blow out the sensors with some compressed air.(Computer Duster) they are likely covered in paper dust and the machine believes paper is present.
Please be sure to unplug the machine before attempting any sort of repairs
Hope this is of some help
Ed
Apr 20, 2009 | Fellowes SB-99Ci Shredder
Shredder does not pull in paper to be shredded.
you might be putting to much paper into the shedder
try putting 3or 4 sheets at a time and put a little oil on the blades
Feb 18, 2009 | Office Equipment & Supplies
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Shredding no more
if the unit is pulling paper thru but not shredding your cutters have separated for some reason. If not pulling paper thru but machine is running you probally have a broken gear causing cutters to no longer turn you may hear a clunking or grinding noise or gear may be stripped if shredder sounds like it is spinning freely. Contact manufacturer for parts availability.
Nov 26, 2007 | Royal CIA 12X Shredder
507 people viewed this question
jasbo
jasbo
