Question about Pool & Spa
Turn on pump and it only has a humming sound. Motor does not start
  • 8,404 Answers
Check your start capacitor. Probably best to remove the motor and take it to your pool supply place.
Posted on May 16, 2010
I have an in ground fibreglass saltwater pool and the water will filter will not pump.
a humming noise is a frequency noise meaning the motor is not running
check / replace the start/run capacitor for the pump motor
call an electrician for a proper diagnosis
Dec 28, 2016 | Pool & Spa
Car not starting at all with only a clicking sound.Low level humming sound for a few seconds after removing the key from the ignition. New battery, all dashboard lights, alarm ok......
bad starter motor or soleniod
hum or whir or clicking
means starter is not throwing out to the flywheel teeth to turn the motor over
or cable from battery to starter needs inspection
May 30, 2016 | Cars & Trucks
Pump makes humming noise impeller spins slowly
sounds as if pump has stuck start winding switch , try giving Motor not the pump a sharp knock with a rubber mallet when you 1st turn on , this might jar it loose if not a new motor might be needed , if motor was larger then say 2hp then id say get it fixed at a motor repair shop due to cost saving but smaller sizes it's not worth it most times
Nov 23, 2013 | Pentair 1.0 Hp Whisperflo Pump
Tub turns on but no bubbling and it makes a humming sound
A humming sound typically is caused by a locked pump, the motor is trying to turn but something is preventing it to start. It could be a bad bearing or some debris in the impeller. However the starting winding switch or also the winding itself could already be burned. The pump has to come out in any case.
Oct 16, 2013 | Pool & Spa
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Pump does not turn on except for a humming sound and shuts off jumping the electric breaker
This could be anything from a stuck impeller to bad windings in motor. If you open the pump at the lock ring and remove the difusser from the impeller you can see if you can spin the impeller, If it won't move is it something holding the impeller up remove it. If notit is probally a bad bearing and you should replace the motor. If the Impeller turns try turning it on and caerfully try to spin before it kicks the breaker. If it is sort of stuck and does not want to turn the motor is bad and needs to be replaced. If it spins and won't start same thing, If it spins and starts it is probally a start capicator. Shut the power off at the breaker remove the back of the motor the capacitor will be a small black or silver cylinder with 2 or 3 wires clipped to it. Remove this and take it to a motor shop and get an exact duplicate. and that should fix it. When putting back together be sure to lube all "O"rings and refill with water. Hope this helps.
Jun 02, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Motor hums, but propeller will not turn
I HAVE A ZOELLER PUMP AND THE IMPELLER WONT TURN I TAKE A SCREW DRIVER AND TURN IT AND IT WORKS STOP THE PUMP AND IT HUMS CAN THE IMPELLER COME OFF IF IT DOES HOW DO YOU TAKE IT OFF.
May 06, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
The pump lost vaccum, now the motor shut off and pump only hums.
Prime the pump. If it still just hums, try to turn the impeller. If the impeller is not jammed, and the motor hums or it doesn't start at all, the motor may be bad. Check for correct voltage of the incoming power wires inside the motor connection housing. Sometimes turning the circuit breaker off, then back on will fix it.
Jan 15, 2009 | Garden
Washer ax6245wv0 roper washer
  Sounds like something in pump.  This is causing motor to hum and not turn.  Motor is going off on thermal overload.  This is why the humming stops.  It may be possible for you to tilt washer back and access pump.  Remove clip on bottom and top and pull pump off motor.  Try and turn pump.  Remove hoses and see if you can see obstruction.
Oct 14, 2007 | Roper RAS8445KQ Top Load Washer
Pool & Spa Logo
463 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
