Question about Sony Dvcam DSR-PD150 DV Digital Camcorder
Pd 150 is showing green picture in EVF and video
Sony pd 150 is showing green picture in evf and video out. Colorbars look ok.
5 Suggested Answers
SOURCE: SONY PD-150 - can't hear sound from recording
Could be the volume level, which is found on the bottom-left of the flip-out LCD screen.
Posted on Jun 07, 2009
  • 21 Answers
SOURCE: I am getin aproblem to capture from my sony pd
If is not fisical break od DV convertor on camera for firewire, then you have problem with damaged ic circle on board in camera. It`s very little chance that you can fixed that by yourself. It will be problem to change main board or circle DV interface. All of  this is complicated and expencive. I recomended you to buy one of Sony cameras ,mini DV. All of that cameras can read DVCAM and you can put everything in your PC. This is cheaper then fixing your camera. I hope that I was helpful!
Posted on Dec 02, 2009
Kasm279
  • 95 Answers
SOURCE: I need to download the sony DV DSR-PD 150 P driver
The camera doesn't need drivers, but it does need an application that will take DV input. If you have a Mac iMovie will do that, provided you have the FireWire cable for it.
Posted on Apr 02, 2010
welcomejee
  • 10594 Answers
SOURCE: there is dirt in the
Yes, you can clean EVF by yourself, its easy.
Lift up EVF, you will see little 2 screws on bottom side, remove these screws that is stopping lock, now press lock downward and slide EVF upper casing upward to remove it from base assembly. Use good quality cotton swab/ bud to clean EVF lens and EVF screen and put things back in reverse order.
Below is an exploded view that shows EVF casing removal procedure.
Hope this info will help you.
Let me know if you have additional question.
Thanks.
Posted on Nov 22, 2010
Everything works except the view finder. Both through the eye piece or the display screen,
hi,
If EVF and LCD screen not giving picture, check the change over switch inside the monitor hinges clean it with contact cleaner spray, if it is OK, open and check the circuit on the mother board,
Feb 28, 2016 | Canon ZR40 Mini DV Digital Camcorder
Sony camera trv3100 it's not video out
did you check the picture through the EVF ? if OK,
the fault must be with the monitor cable, open the cam replace it.
Feb 21, 2016 | Sony Video Cameras
How can I fix the button that turns on the EVF and turns off the screen? It isn't working.
sir,
I don't understand your question!! how can we use EVF for this model in which it is not fixed from the company, the tilting type LCD is very clear and user friendly in this model.
some old models comes with EVF there may be a small switch beside the EVF. and in some models comes the switching options in the setting menu. if your model is like that you try it in the S-menu.
Jan 10, 2016 | Sony Cyber-shot DSC-HX1 Digital Camera
My SONY HDV 1000u have been put up in a knapsack on my wardrobe for six months and is now showing vertical white n grey lines on LCD n on playback,tried cleaning tape nothing. Suggestions plz?
hi,
Remember any of your Electronics gadgets not using for a long period, you mus detach the battery, put it separately. how is the picture in the EVF, in this case I think a cleaning and servicing will cure the problem, open the LCD side, clean all the connectors with CRC liquid,
Dec 13, 2015 | Sony Video Cameras
View finder on my Sony HVR-Z5U isn't working, I can film through the flip out screen, but unable to use the eye piece view finder
POSSIBLY THE RIBBON CABLE THAT RUNS FROM THE EVF (VIEWFINDER) TO THE MAIN PROCESS BOARD SHOULD SWITCH REFERENCE TO EVF WHEN LCD PANEL MONITOR IS CLOSED REGARDS JOHN
www.jvsvisual.com
Mar 14, 2013 | Sony HVR-Z5U High Definition DV Camcorder
Have a fuji finepix S5600, but my lcd remains black even the camera is on! i can see the pictures i already made at the lCD. But LCD is not working if i want to make new pictures??
Hello, I think I know what the problem is..we'll see. On the back of the s5600 there is a button marked EVF and LCD(EVF on top LCD underneath) try clicking this button to see if your LCD screen becomes available, only one of these can be used at a time and the default for playback is the LCD screen. However if you have set it to EVF it will revert back to this format when you leave playback and try take new footage. I hope this helps and it is nothing more complicated. I have some problems myself and know how it feels. Alan
Aug 29, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
My s5000 screen is all white in record mode. It breifly had a picture then when I pushed the shutter it went white again????
Does the EVF work? The small view finder above the LCD screen. You can switch to it using the EVF/LCD button on the right side above the main display. If it is okay then you'll likely need a replacement LCD.
Jan 04, 2010 | Fuji FinePix S5000 Digital Camera
MY Hvx 200 Is totally Black when I turn it on. the display and playback of my old footage works fine but the picture is totally black. any Ideas When I switch the camera on, the view finder is totally...
You should go into the menu, camera settings and set the evf to on. EVF stands for electronic view finder. This can be set to be on when the lcd is open or closed. CAreful, if the evf is set to on and you point the viewfinder towards the sun, it will burn white marks into the viewfinder and ruin it.
May 09, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Mar 08, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Sony Dvcam DSR-PD150 DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
