10 yr old Toshiba 36" tv about 2 weeks ago turned tv on and screen had green hue with 1" horizontal lines about 2 " apart went side to side. then next day screen had red/pink hue all lines were gone. I tried to adjust using remote to no avail. Now picture is perfect with all colors good, except ther is no green available. Especially easy to notice when tuning in golf or the weather radars. NCAA basketball was good except no green. Where you think green should be like in golf the grass is a gray/brown color. Never had a problem with this tv in 10 yrs. Is this worth tracking down or is it time for a new TV. Thanks in advance Michael
  • 8,617 Answers
Sounds like the coolant needs to be changed. Try looking into the lens of the green CRT and see if it has bacteria growth in it. This is a common fault with all projection tvs when they get some age on them. The coolant isnt too hard to change and its relatively cheap to purchase around twenty dollars.
Posted on Mar 31, 2008
    Genius:
  • 1,694 Answers
Bad solder connects CRT board RGB circuit or bad CRT....
a qualified tech would need to check it...............T.
15 yr old sony trinitron tv
It sounds that the video output section circuit bard to this TV have some loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder. The video output section board can be located at the neck of the picture tube, will directly plugged on to it. Check it. If you wish to know more details about single color display screens, check this site. It has details to that problem. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 10, 2013 | Toshiba CF27H50 TV
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
I've had my Toshiba 46RV530U less than 2 years,
Diana, did you ever find a solution? My Toshiba (same model) is about 2 years old and it started getting these 4 horizontal lines spaced pretty far apart and a double image at bottom. When I lightly tap the top of the TV, they went away. But now that is not working. Please let me know. Thanks.
Jeff
May 15, 2010 | Toshiba REGZA 46RV530U LCD TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Samsung hlr5667w green screen issue
test test test 16:47 do not answer
please do not answer test test test
Jul 05, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
done tv needs professional help. the Electron gun internally is no longer capable of spanning the entire screen. Not likely anything can be done outside of professional help
Aug 16, 2007 | Toshiba CF36G40 36" TV
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
