Question about Zenith IQB50M90W 50" Rear Projection Television
Zenith IQ6097DT 60 inch big screen
TV started bowing at the top. Then the picture went off and there was the rainbow at the top and bottom bowing, mostly green color. Then there was a pop and it turned off. Now it will not turn back on. Never had problem with unit. Please tell me if this can be fixed, what it needs to be fixed, how much will it cost and will I be able to fix it myself
  • aggie4life Apr 01, 2008
    Could you be more specific about the convergence circuit repair? For example what is it and how do you fix it. Please and I really appreciate all the help.
  • Anonymous Mar 04, 2009
    I have the same problem. But I have a Yellow and Blue rainbow top and bottom. Hear popping once in a while but it still works...
    Genius:
  • 1,694 Answers
Convergence circuit repair plus fuse in the power supply,
usually 300.-400.00.....................if you are mechanically
able and can solder well,it is possible to DIY...................T.
Posted on Mar 31, 2008
  • Vista Electronics Apr 01, 2008
    The convergence IC's are mounted on the large heatsinks on
    the chassis....STK392-110 ?? They are soldered in....and
    chassis / or PC board must be pulled....requires considerable
    knowledge and skill......fuse device also soldered- in....power supply area......................................T.
My plasma tv just started having water colors flashing on top and bottom?
what do you mean water colours? do you mean like a faint rainbow type of thing, if so that means a magnet is or has been too close to the screen, and as far as I am aware magnet damage can not be repaired
Jan 04, 2015 | LG 60PV450 60-Inch 1080p Plasma HDTV
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2010 | RCA HD52W59 HDTV Projection Television
60 inch zenith tv m#d60wlcd picture all blue
the part maybe no longer available. p/n
3141VSN180C its an LG part called an optical block but the substitute is for around 900 dollars
3141VSN180H
Mar 13, 2009 | Televison & Video
Tv is messed up
I got a question.
Do you have any stereo speakers anywhere near your television?
This sounds like something a magnetic field could cause from speakers being too close to the tv.
If so try to relocate them and see if the problem goes away.
Jun 15, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Bowing in the middle like an hour glass
about the zenith it seems you have the flyback transformer malfunctioning - try to change it - delfo
Mar 22, 2008 | Televison & Video
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 60PP920217F bows in on top and bottom
convergance amp ic are bad.
Nov 28, 2007 | Philips 60PP9202 60" Rear Projection...
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Jan 28, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Zenith IQB50M90W 50" Rear Projection Television Logo
212 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
