Question about NetGear WGT624 Wireless Router
Connection propblem I have read the prior problem and followed the correction. I have since been able to correct the connection propbemel with my laptop and my NetGear. Now that the connection is strong at 54mbps, but I still can not get out to the internet. Why?? Help!!
  • thatsall Apr 07, 2008
    I don't think that is it because my upstairs tenant has jumped on our network and got out to the web. I have recently removed all the security off the router, and i was still unable to get on the web. I have recently added Symenatec security on my Laptop. that did not help or hurt my connection, but still no web.
  • 123 Answers
Thatshall,
ur router might be the problem..coz there are some devices that when u bought it,may not function well,coz it is a factory defect..use ur warranty,let the store where u bought that replace it..
Posted on Apr 07, 2008
  • thatshall,
    reconfigure ur pc..there are just some settings that u missed to configure it..
I upgraded my Jandy RS controller to run Jandy epumps and installed a new Pentair Mastertemp 400HD heater. Prior to connecting the pool heater thermostat all worked perfect. all instructions stated to...
bad info firemans switch is continuity only if hooked up to firemans switch run new wire from each end of firemans switch to pins 1 and 2 of long plug along top of PCB board make sure to read inside schematic for dip switch positions firemans switch to control heater on and off you will have to turn heater all the way up max setting for temp
Jan 16, 2015 | Jandy AquaLink RS OneTouch Wired White...
Removing thermostat on 88 suburban
Make engine is cool. Relieve pressure from cooling system with radiator cap. Follow upper radiator hose to top of engine. This will connect to the thermostat housing. Remove bolts and bracket if it has one to lift up on housing to expose thermostat. Note use drain pan under vehicle or partially drain radiator prior to removal. also make sure gasket surface is clean and thermostat is installed correctly. fill and check for leaks.
Feb 06, 2011 | 1988 Chevrolet Suburban
1981 Cadillac with digital displays. The fuel pump was replaced, and since then fuel gauge always reads full. (It was working prior to the replacement fuel pump)
Hello: This could be the fuel level sensor is not connected or the sensor assembly was damaged or bent when assembly was reinstalled or the fuel pump was not installed on the sending unit correctly.
Dec 25, 2010 | Cadillac DeVille Cars & Trucks
When i try to connect to the internet a message appears saying cnnot find I P address
  • Hi, lets try reconnect, by way of initial ("First") connection; this way if there is a problem, a diagnostics test will "Run," and the problem will be either corrected, or identified in more ("Detail"). Click on the "Start" button, in the "right" pane select the "Connect To" (Icon), a "List" of Wireless services appear." Choose the one you a familiar with, or was connect to prior to the problem. If you were connect by any other means, Wired LAN,or Router. Follow these instructions: Open the "Start Menu," click on "ALL Programs, scroll to find; Toshiba ("folder, click to open"), select the "ConfigFree," click on the Connectivity Doctor. The Connectivity Doctor will open, and conduct an diagnostics of all your connections. Follow all instruction thereafter. "Did this solution help?
Feb 03, 2010 | Computers & Internet
Will not boot says operating system not found
if it was working before that message, then probably the operating system is corrupted.
insert the windows cd when you boot your pc and when the message "Press any key to boot from dvd" appear press enter.
Follow the screens to repair Windows. the sytem files will be restored.
Jan 25, 2010 | Toshiba Satellite A105 Notebook
I am trying to install my lexmark x5470 to my laptop but it is not listed
To install your printer do as follows:
A) If you have the CD that came with the printer:
  • run the CD to install the driver and the software;
  • follow the installation instructions
  • do not connect the printer to the computer prior to installing the driver/software; do it only after the installation process is concluded or if and when the install wizard instructs you do do so.
B) If you don't have a CD:
  • read this FAQ: How to Install a Downloaded Driver
  • download the correct driver for your system from LEXMARK:
    Downloads for Lexmark X5470 printer
    Note that here are four different drivers for your printer: one for MAC systems, and three for Windows systems (Windows Vista 32, Windows Vista 64 and Windows XP/2000). Make sure you download the right one. To access the Windows drivers, click on the 'Microsoft' tab.
  • install the driver following the instructions on the FAQ above
Sep 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
CPU turns on but turns off within seconds, rarely minutes into self-fix module. Local technician suggested replacing motherboard. Could this be power supply problem or is it the motherboard.
This can actually be a propblem with the power supply , processor or the motherboard already, but to isolate this problem correctly better if you try replacing first the power supply since this problem is usually cause also by a failing power supply...
Aug 09, 2009 | Computers & Internet
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Dwl-2100ap set up propblem
There's quite a bit to know about extending / repeating WIFI signals.
Read about extending a WIFI signal with a Sitecom WL-130 repeater here.
Sep 05, 2008 | D-Link AirPlus G Wireless Range Extender...
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
16 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
