Question about GE Profile Prodigy WPSE4200A
GE profile top loader, agitator and spin start and stop
I have a ge profile Model# ge wpsr4130w1ww it was given to me so no warranty at all. The washer fills and starts the cycle as normal but then the agitator stops turning wait a few minutes and it starts again this happens repeatedly all through the cycle as if the motor overloads and resets itself. Same with the spin cycle it starts to spin and then cuts out in a few seconds its not the lid switch or a balance issue and it pumps out fine any help would be appreciated
  • 1028 Answers
SOURCE: Newer Kenmore washing machine doesn't spin in spin cycle
motor coupling broke ..this id dohicky between motor and gearcase or worse case gearcase suspect coupler first
Posted on May 04, 2008
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
BIKER T
  • 909 Answers
SOURCE: 7.5kg top loader Whirlpool - 5yrs old. Overloaded
Looks like your motor/gearbox combination is broken. not worth the repair. By the time the top drum is removed, it will cost for motor/gearbox:top drum(will break when trying to remove) and labour. Cost will almost be the same. For the same price i would opt for new because at least you get a proper gaurentee.
Posted on Sep 21, 2009
Testimonial: "This is what I have feared, am waiting on technicians assessment, am prepared for the worst. Thanks for the advice."
heatman101
  • 43501 Answers
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 12, 2010
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
Jun 11, 2009 | GE Profile WPRE6100G Top Load Washer
GE profile top loader washer will not fill with water at all!!
do you hear any humming when it asks for water? do you have flood stop hoses? if you have flood stop hoses take them off this could be your problem. sounds like the unit thinks its full of water if it only washes and spins sounds like you have a bad pressure switch. this should be a covered repair if the unit is brand new. let me know if you have any other questions
Jun 11, 2009 | Washing Machines
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE top loader not agitating
Your agitator splines are probably stripped out.
Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
Mar 04, 2009 | GE WBSR3140DW Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
54 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
