Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
My pc turns itself off as soon as I switch it on,
My pc turns itsel*** as soon as I switch it on the fan seems to make a loud noise if I leave it for a while then switch it back on it does a disk check but eventually turns itsel*** again. Could it be something to do with the fan? I do know that it will not download the service pack 1 when I try and do the updates this is of course when I do eventually get it to work. My pc is acer aspire e380 hope you can help
  • Acer Master
  • 5,660 Answers
If the Processor fan is the one making the noise, it's the problem. (Fan bearings are bad)
A processor operates within a certain temperature range (Thermal range)
If the Processor becomes too hot, BIOS turns the Processor off.
This is a built-in Fail Safe feature, to keep the Processor from burning up. (Literally)
The Processor fan, (Sitting on top of the Heatsink, which in turn sits on top of the Processor), must be spinning, and MUST spin at a certain speed.
(RPM. Revolutions Per Minute)
The Acer Aspire E380-UD420A desktop computer, uses an AMD Athlon 64 X2 4200+, processor.
AMD's run H-O-T!
An AMD processor will burn up in less than 30 seconds, without proper cooling. (Intel's last much longer)
Suggest you replace that fan Pronto, if this is the fan in question!
A Fan/Heatsink combo may be easier to find than just the fan.
The AMD Athlon 64 X2 4200+ processor, uses a Socket 939 processor socket,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22Toledo.22_.28E6.2C_90_nm.29_2
Information on the Socket 939 processor socket,
http://en.wikipedia.org/wiki/Socket_939
When buying a Fan/Heatsink combo, you look for what processor socket the processor uses. Then you look at the physical dimension size of the Fan/Heatsink combo, and determine if it will fit.
As you can see from inside your computer, the Processor sits sideways when mounted.
Therefore, you have to look at the Height of the Fan/Heatsink combo, to see if it will fit in the case.
You also have to look at the Width, and Length. There may be Electrolytic Capacitors on the motherboard, or Ram Memory module/s, or some other hardware components in the way, that may only allow a certain Width, and Length.
Just one example, of a Fan/Heatsink combo for a Socket 939 processor,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2604150&CatId=1997
Be sure the computer is unplugged from power, before reaching inside the computer.
Also be VERY sure to observe Anti-Static precautions.
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components, inside a computer. You probably won't even see it, or feel it.
Computer unplugged from power, computer case open, TOUCH the metal frame of the computer case, to relieve your body of Static.
IF, you get up, and walk away in the middle of working on your computer, upon your return TOUCH the metal case again.
Processors are the MOST susceptible hardware component inside a computer, to Static shock.
Also.
Heatsink:
An average Heatsink is composed of a flat plate of metal, with tall fins protruding from it.
Heat is absorbed from the top of the Processor's case, to the metal plate, whereupon the heat is absorbed by the tall, thin fins, and radiated away.
The Processor fan pushes air in-between the fins, and helps carry the heat away.
The top of a Processor's case, and the bottom of a Heatsink, are not perfectly smooth. A microscopic view would reveal 'Pits, Valleys, and Hills'.
These imperfections create an air pocket.
AIR is an Insulator, not a Conductor.
Air does not conduct heat very well.
Thermal paste is a compound made to fill the above mentioned imperfections. It is an excellent Conductor.
It ABSOLUTELY must be used!
Do Not reuse old thermal paste. The properties of the paste break down over time. Even if the thermal paste looks to be good, don't.
The cost of good thermal paste is very little. $2 to $4 from a 'Mom and Pop' computer store, $6 on up online.
The top of the Processor, and the bottom of the Heatsink MUST be thoroughly cleaned. I use an old plastic credit card (Anti-Static, and won't scratch the processor case), to clean these areas.
I then follow with Q-tips dipped in Isopropyl Alcohol.
(Rubbing Alcohol. 91 percent alcohol is best, but 70 percent will do. NO to 50 percent. It's 50 percent water, 50 percent alcohol.
CAUTION!!
Isopropyl alcohol is Extremely Flammable!
Use in a Well ventilated area, with no sparks, or flames present)
Takes a few Q-tips dipped in alcohol to remove the gooey mess of the old thermal paste.
How clean does it need to be?
Clean enough to eat off of.
Literally.
Questions?
Post in a Comment.
Posted on May 17, 2010
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
My panasonic lumix ls80 digital camera turns itsel*** as soon as i turn it on
Be sure that your batteries are fully charged and in fact using name brand rechargeable batteries. If you are using Alkalaid, make sure they are fresh. Alks after a use that runs them down will come back after awhile for some more pictures. If you have fresh batteries and the camera turns itself off after turning it on, it probably has a problem in the power supply section or the switching section on/off on a circuit board.
May 20, 2010 | Panasonic Lumix DMC-LS80 Digital Camera
My pc turns itself off as soon as I switch it on, the fan seems to make a loud noise, if I leave it for a while, then switch it back on, it does a disk check but eventually turns itself off again. Could it...
Hi
Which fan. If it's the power supply fan then the power supply needs to be replaced. It could be damaged due to a heat related issue. Most likely it's the CPU fan that is going bad. Once the fan stops then the CPU heat goes up dramatically, the CPU then shuts down because of the high heat. CPU may be damaged also. Get this machine to to a reputable repair person as soon as possible.
Mar 24, 2010 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Filters all seem clean and clear, suction is fine,but loud noise
Sounds to me it could be tha fan impellor.
This is vac's etc... email us if you need to.
vacs.etc@live.com
Nov 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Projector stays on for 3 minutes then turns itself off
Hi Chipped Rice
The loud buzzing noise you heard was the colourwheel that gave in.
Now what happens is , the machine will turn on and go through the whole cycle and as soon as the colourwheel is supposed to start doing it's stuff the Projector will switch off because there is no response from the coulourwheel itself.
You will have to replace the colourwheel unfortunately as it cannot be fixed.
Thanks for using Fixya !
May 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
Loud whirring noise when mains switched on but PC still off
Most likely worn bearings in the fans.
If that's the case, replace the fan/s.
Jan 23, 2008 | Dell (S423) for Dimension 8100 (3F546)...
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
244 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
