Fabric softener dispenser not draining - Washing Machines
jsrock516
  • 5911 Answers
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Posted on Feb 11, 2008
barkencoa
  • 3463 Answers
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: fabric softener dispenser no longer works on my Bosch
Remove soap drawer completely from washer, and thoroughly clean all parts of it, paticularly the conditioner compartment..
Get a piece of stiff wire, and make a right angled bend in the end of it, then poke the wire into all the holes in the top of the soap drawer compartment to clear any possible blockage.
This should solve the prob.
Please rate my solution.
Thankyou.
Posted on May 20, 2009
MNTECH
  • 1543 Answers
SOURCE: Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
Posted on May 23, 2009
SOURCE: remove and replace fabric softener dispenser on kenmore model 20952992
I just did it. All you do is pull up on the blue part -- put the fingers of both hands under the rim and pull. It isn't screwed or bolted on. If there's a lot of gunk built up, it's all the harder to pull up. Be prepared for some yucky stuff. It would be nice if that whole section would come out, since you have to clean the area below with Q-tips.
Posted on Jan 09, 2010
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
F3 error on my whirlpool washer
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Oct 11, 2010 | Whirlpool Washing Machines
Kenmore electric range gets a f1/f3 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 10, 2010 | Kenmore Slider/Casement Air Conditioner
Fabric softener is not dispensing
drain tube stopped up with softener needs cleaning
Feb 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code FO3 Kenmore washer #417.44072300
Oct 14, 2009 | Kenmore Washing Machines
Error message E3 on my Kenmore Elite Dryer
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
I have a F 03 code.
Hotpoint aquarius wf 630 error code f-03 how do i fix
Aug 14, 2009 | Washing Machines
Error code 03 what does this mean
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly. The fabric softener dispenser works on a siphoning principle. Make sure that the siphon hole in the dispenser is clear and not restricted or plugged. You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it. Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer. You can use the diagnostic test described below to test the fabric softener dispenser. If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining. You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer. You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum. To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump as shown in the second image below. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Jul 09, 2009 | Washing Machines
Fault code
Apr 12, 2009 | Washing Machines
Washing Machines Logo
208 people viewed this question
Top Washing Machines Experts
