Question about Health & Beauty
Has no manual
The machine has no manual and i do not know how to work it. It is a homedics type par 120.wax machine with timer
    Problem Solver:
  • 19 Answers
Http://www.homedics.com/home/FAQ-paraffin-bath/
Here is a website that you might find helpful. Also here is the website to contact homedics customer service. You could get them to send you a manual. http://www.homedics.com/home/contacts. They should be able to help you. There is also a website called manualsonline.com. You can download tons of different manuals from there. I hope this helps! :)
Posted on May 18, 2010
Do you have the instructions or user manual for Homedics Paraffin Baths from several years ago.
I have the manual for the ParaSpa Plus. Your image matches the model. Do you have a specific question?
Sep 27, 2013 | Homedics Paraspa Plus Paraffin Wax Bath"
Fisher and Paykel diverter won't work
The plunger should be out when wax solenoid is hot.
When non energized outputs to drain pipe.
Check to see if it's the right way around.
Oct 27, 2012 | Fisher and Paykel Washing Machines
Has no manual
hello... here is the link to the closest product now shown at homedics http://www.homedics.com/home/spa/paraffin-baths-wax/paraspatm-plus-paraffin-bath.html
before you go to that link you will see that the item is out of stock and the manual does not load up.
You can call the company and ask for the manual Phone: 1-800-466-3342 (1-800-HOMEDICS) Consumer Relations hours are 8:30am to 7:00pm Eastern Time, Monday through Friday.
please rate my answer as very helpful thank you. joe
Mar 24, 2010 | Health & Beauty
Sope dispenser will not open when running
Hi
Thanks for using FixYa. Many dishwashers (but not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open.
Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced. Older Kitchen-aid dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) Kitchen-aid dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | KitchenAid Dishwashers
The soap dispenser fails to open at times
Hi
Bosch dishwashers (not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced.
Older Bosch dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work.
Thanks
Rylee
Oct 12, 2009 | Bosch Dishwashers
GE profile model GSD 4120y70BB the second soap dispensor does not open at the right time. When cycle is done and the door is opened the soap has just ran down. It is like it is opening to late.
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced. Older GE dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) Maytag dishwashers and many newer Whirlpool and Frigidaire dishwashers use a wax motor to open the soap dispenser; this wax motor does receive 120 volts to work. The plunger inside the wax motor slowly moves and pushes the plunger and door open. This is what a wax motor looks like.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 06, 2009 | GE Dishwashers
Soap dispensor not opeaning, and soap tabs are not dissolving
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced. Older GE dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) Maytag dishwashers and many newer Whirlpool & Frigidaire dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work.
Thanks
Rylee
Aug 04, 2009 | Frigidaire Dishwashers
Washer will not Wash/Spin
take the back of the top console off and there is a service manual there that will help you a lot more than i can type if the guy didnt take it with him anyway, doesnt sound like a door lock problem tho because it will give an error for the door and yes it is a solinoid, the older models had a wax motor
Jul 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Soap door is locked shut and will not open, we have spun the dial around to the point that it should open and it did not work.......
Hi
Many dishwashers ( but not all ) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost it's ability to bend properly and needs to be replaced. Older GE dishwashers used an mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer ( plastic liner ) Maytag dishwashers and many newer Whirlpool and Frigidaire dishwashers use a wax motor to open the soap dispenser, this wax motor does receive 120 volts to work. The plunger inside the wax motor slowly moves and pushes the plunger and door open. This is a what a wax motor looks like.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | GE 24 in. GSD4000J Built-in Dishwasher
Health & Beauty Logo
281 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
