Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Printer freezes after about 20 min. No buttons
Printer freezes after about 20 min. No buttons function but led screen is lit with time of freeze up. If I unplug it or shut i*** it initializes when turned back on and works perfectly....until it freezes again.
  • 152 Answers
HPM1522NF - Freezes or Restarts Randomly.
Hello, this is caused by the "formatter" board being defective, it needs to be replaced. This printer also has a scanner problem, the error code of 5 and 8 are reported. This printer should be covered under an HP Extended Warranty Until Mar 23, 2011 Contact a local HP Authorized Service Center for further assistance.
Please contact your local Hewlett Packard Repair Center.
I hope this has been of assistance.
HPPARTNERLOCATOR
Posted on Jan 17, 2011
Reset counter
By the way, what is the make and model of your printer?
  1. Resetting the Drum Page Counter
    • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
    • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
    • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
    • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
    • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
    • 7 Turn the printer off and back on.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Office Equipment & Supplies
Error 3
Perform an EEPROM reset:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
times Orange EEPROM reset
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 23, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Printer maintenance is in progress. scan after it is complets. code:2,114,0
clear the EEPROM:
button pressing
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Dec 10, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My canon pixma mp 160 just keep on alarming, what shall i do to fix it, ty
160 resetting errors
button pressing
procedures below.
procedures below.
Nov 24, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I suspect a power supply fault. Many times what happens is the filter capacitors overheat and become defective. If you take a look at the power supply board and find electrolytic capacitors with swollen tops, that is most likely the problem. The capacitors will need to be replaced. If you are not capable of replacing the components you can probably buy a replacement board.
Good luck, let me know how you make out.
Mar 24, 2010 | HP LaserJet M1522nf Multifunction Printer...
My printer ink absober was full. my printer display e27 code. what can i do?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-9
Apr 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E 4, 2 canon pixma mp 160
E42 means scanner error. May require a hard reset(disconnect from power supply for 30 min). Otherwise may require factory reset procedure to be applied. Follow the steps below:
Mp160 Reset Counter
Service mode operation procedures -
press the Power button while pressing and holding the Stop/ Reset button.
the printer will move into a service mode. (Waiting for menu selection)
according to the function listed in the table below.
the LED lights alternately in orange and green, starting with orange.)
The number of the Reset button pressing LED Function Remarks
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
Jun 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon printer mp150
can you try to reset, here are the steps
Mp150
Reset Counter
button pressing
procedures below.
procedures below.
Feb 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Unasble to print
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Nov 07, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Service Error with my cannon printer 160
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Oct 24, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
1,098 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
