Question about Magic GigaBank (IUSB12HD10) 12 GB USB 2.0 Hard Drive
When I put my i/omagic Gigabank Micro USB12HD10 device in my computer usb port the windows explorer won't open subdirectories or files. The Windows explorer recognizes the drive and shows the subdirectories but wont open the subdirectories or files. The blue light comes on and then the yellow light. The windows hourglass starts and stays on but the screen doesn't display any results. There is no clicking sound coming from the Gigabank device.
Need power cord
Try this OMagic Cables (bottom left CP1205) You may need to write (email) to them re European distributor/retailer
Feb 12, 2014 | IO Magic Corporation GigaBank (I250HD35)...
My I/Omagic not working
You need to add the device before it can work.
Click on start on your computer screen(title bar).
Go to Control Panel.
Click on Add Hardware.
Insert the Device Cd if it has. But if you have and your device is plug and play.You click Next and follow the steps.
Jul 22, 2010 | Yahoo Messenger
Cruzer micro 4gb does not start on windows xp
If you are using Windows.
Open the Windows explorer.
Plug the device in a USB port and wait for the computer to recognize it. After it is recognized the Windows Explorer will show two additional icons, one of them a CD-ROM.
Click the icon with the CD-ROM, and it will execute the U3 operating system. A small yellow icon with a U3 label will appear on the task bar. Right-click the icon on task bar and select the "Open U3 Launchpad". Point to the Settings button on the right side.
Right click that button and select the U3 LaunchPad settings
In the window that pop up point to "Autorun" button and click it.
Click the button that will say Enable.
After that it will launch automatically whenever the device is recognized by a computer.
If the U3 launchPad is missing from the device you can download it from the SanDisk site. Here is the link. Download it and install it on your computer. Note:It does not launch on MacProducts or Linux.
Jun 28, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
HOW DO I USE THE MEMORY STICK?
memory sticks are plug and play devices.
simply plug in the stick on the usb port and the device would get automatically detected. it would be visible in the my computer window.
you can use it for storing your data.
Feb 02, 2010 | Sony 512MB Micro Vault Ultra Mini USB 2.0...
I lost the directions for using a micro mini
Find a USB-port on your computer.
Insert the flash-drive into the USB port.
Windows will report "found new hardware", and will assign a "drive-letter" (e.g., 'A:' is your diskette drive, 'C:' is your disk-drive, 'D:' is your CD-ROM device) to the device.
Then, use "Windows Explorer" to drag-and-drop files onto the new drive-letter (probably 'E:').
Nov 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I need a driver for the webcam HI-VAL HVWC200
Generic drivers already in Win XP, but if you want camera specific drivers, go to the manufacturers website and download them. A good program that works very well, is free on the web and is called YAWCAM. Google search for it and download.
Jul 22, 2009 | Hi-Val i/oMagic Webcam
Won't turn ON
tmilligan,
This is an external burner right? They usually have a power supply and wall plug and don't power up from the USB. To make sure check the drive to see if there is a plug for a power cord on the enclosure back. My money is on that you will need to call some friends to help you move the desk.
randy320sgi
Jan 16, 2009 | Magic INCDRW4048 MagicSpin (INCDRW4048)...
Problem with 8 GB Micro Vault Classic USB Flash Drive (vista)
you did not state the problem.
here, just answer this:
1. does it work with other computers?
2. when you insert it in the usb port, is it detected and "...device...ready to be used..." ???
3. can you see it in Windows Explorer?
4. if not, check if it needs formatting
..ok you're set!
Sep 25, 2008 | Computers & Internet
Cruzer micro 2.0GB does not work anymore, it started flashing and then it stopped. When connected to USB port the computer does not start and when connected afterwards the device is not recognized by the...
Some times it happens that Windows explore do not recognise the USB flash drives. There may be some causes: 1. Ckheck your flash drive & ensure that it was not burnt or have any physical damage. 2. Start the computer without flash drive and connect the flash drive to it. Noe ensure that your computer is not hanged.If your computer hanged than the flash drive is damaged. 3. if your computer is not hanged and not dectecting the drive,(fore windows) go to My computer, right click, properties, divice manager. In the device list see USB serial bus controllers. click + next to it to see the sub devices. 4. Now see that the computer has a listing for the flash drive. The listing may be as "Usb mass storage device", "Drive company name: etc. 5. If there is listing no listing for flash drive just disconnect it and see the device manager listing. some changes will occur or mouse pointer will show busy. Again reconnect the flash drive the same thing happens. 6. if your flash drive worked as in step 5 that means the the drive is ok and the compueter is ok. There is prblem with driver of flash drive that is currently installed. Please upgrade the driver from your flash drive manufacturer or it is ready to use device just unuinstall it from the device manager listing. Restart the computer. after restart connect the flash drive it will detect the drive. 7. if there is still a problem go to start run & type regedit and press enter to run registry editor. In Hkey_local_machine>software>Cruzer micro and delete it. restart the computer. 8. You wrote that if you connect it to USB port computer does not start. If above step 1 to 7 does not work means there is strong possibality of reading problem means the flash drive has errors on it and file system is damaged. This same thing happens with Cd drive with a cd having corroupt file system. i will prefer to take the flah drive to an local hardware expert or manufacturere.
Jul 23, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Magic GigaBank  (IUSB12HD10) 12 GB USB 2.0 Hard Drive Logo
66 people viewed this question
Top Magic Computers & Internet Experts
Computer Links
john h
Are you a Magic Computer and Internet Expert? Answer questions, earn points and help others
