Question about Amana ALE643RB Electric Dryer
My dryer is not heating up. I change the heating ele and still not heating up?
    President:
  • 1,430 Answers
First check your venting if all is clear it could be several things, thermal cut out, thermal fuse. These parts are very inexpensive and all are easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that can walk you thru the troubleshooting of your problem. It may be a different model but the troubleshooting will be the same. You can also get diagrams and illustrations of your specific model by entering your model #. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Posted on May 16, 2010
Estate by Whirlpool Dryer DWSR-ELE-2406028-FM54 doesn't heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 20, 2011 | Dryers
Dryer has power, motor runs, Won't heat. Kenmore Dryer Mod# 118 C68932792 Serial # MJ 3787524 Type - C007 ELE 2386824 EH54
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 10, 2010 | Kenmore Dryers
I have a type DHZN-ELE-2406024-EL54 model
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My dryer works but does not heat
ihave a crosley ele. dryer works will not heat take out the drum or take the belt loss and it heats
Apr 08, 2010 | Kenmore Dryers
The problem is with one of the thermostats or thermal fuse a simple continuity check will find the faulty tstat. Check the video on replacing a heating element it will show you how to check these other fuses. This is not the same model but the testing will be the same.
Hope this helps
Mar 24, 2010 | Amana ALE643RB Electric Dryer
Dryer works but no heat
heating element needs replacement
Oct 30, 2009 | Dryers
T|he heating element won't stop heating
Hi, The element has broke and shorted out against the metal on the dryer. You will need to replace the element. If this is a rear access panel dryer, here is how to get to the ele UNPLUG the dryer! Remove the rear panel of the dryer and locate the element on the right hand side. Plug the dryer back in and test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. I hope this helps you.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Kenmore 62602 Electric Dryer
Dryer will run about 5 mins. then trips the circuit breaker.
I would change the breaker frist and see if that sovles the problem
Oct 14, 2007 | Kenmore 62602 Electric Dryer
Amana ALE643RB Electric Dryer Logo
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
