Question about Haier hwr10xc6 Air Conditioner
HAIER HWV10XC6 The window instalation kit's bracket can't support the weight of the unit and the upper frame and curtain is thin plastic - no security. I caught the unit as it was falling out of the window. Now I have a bracket that is bent and twisted.
  • Anonymous Apr 01, 2008
    If I wanted to be a blacksmith I wouldn't have bought a finished product. Thanks antway dodofel.
  • 241 Answers
Fabricate a new bracket that can support the unit weight and for the safe of the unit also.
Posted on Mar 31, 2008
6ya staff
SOURCE:
How to replace the factory casper/camber equipment on a 1992 gmc 1/2 ton truck? I am told there are knock out that need to be taken out?
1. Original control arm does not allow adjustment of caster and camber. caster and camber may be adjusted only by using adjustment kit ( gm # 15538596 ) Raise vehicle, and support under lower control arms.
remove and discard upper control arm to frame bracket bolts, nuts and washer.
2. remove large washers welded to upper control arm frame brackets. remove wield beads from upper control arm brackets. grind area smooth. install adjustment cans to bracket.
3. install bolt,adjust caster and camber to specifications by rotating bolt head.
Dec 13, 2013 | Cars & Trucks
Removing the windows on a 1994 Viper
The 1994 Dodge Viper RT/10 comes with side curtains, not windows. That is they are a see through plastic material sewed into a metal frame structure to allow for all weather use (not!).
Start by opening the door and locating a thumbscrew against the frame of the door post. Unscrew the thumbscrew and remove. It should have a rubber retaining lanyard to help you to not lose the screw. Once the screw is removed, push the window curtain toward the front of the car and pull up. There are two metal pieces that go into the door and latch onto a post inside the door. Reverse the process to put the window curtains back on.
May 12, 2013 | 1994 Dodge Viper
What can I use to repair a small hole in my coleman air mattress?
Hi rh57...
I will recommend that you use some contact cement, and a piece of thin plastic like a plastic drop cloth, shower curtain, etc.
Cut the plastic piece that will be using as your patch about 1" X 1" square.
Locate the hole in the air mattress, deflate air mattress, apply contact cement lightly to the air mattress approximatly 1" X 1" and the piece of thin plastic material you will be using as the patch over both entire surfaces of the patch and mattress...let it all dry about 20 mins.
After it is dry then apply the patch to the hole in the mattress, apply a weight to the top of the patch, let sit about half an hour and you are done
Hole fixed
Please take time to rate me thumbs up
Sep 14, 2011 | Garden
I have a husqvarna lawn tractor that came with a 50lbs weight and bracket. It did not come with the installation for the bracket and weight.
Without a picture I will guess this is a rear weight kit for a snow blower attachment. It mounts on the rear of the tractor frame.
These mounting instructions are single page drawings that come in the box with the kit. Almost all of us throw them away when done.
If you can't figure it out you can call Agri-Fab and they can send you the assembly instructions (for a cost) Their number is (800) 448-9282
Jan 11, 2011 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Manitowoc Ice machine only makes 2/3 bin of Ice and shuts off
The unit shuts off based on the magnetic reed switch in the plastic curtain on the front of the evaporator. If the ice is not falling as one single sheet with about 1/4"-3/8" of a bridge conecting all of the cubes then the ice is too thin. When the ice falls (in a single sheet of ice) if there is enough ice in the bin to hold that ice up and keep the curtain open the unit shuts down. A full bin may only be what appears to be 2/3 or 3/4 of a bin full because the ice sheet is propped up behind the curtain. If the ice sheet is too thin and does not fall as a single sheet more often than not a single cube or a piece of a cube can get caught between the curtain and the evaporator plate. This can shut the unit down for several hours until that piece melts and the curtain closes again.
Dec 19, 2010 | Manitowoc - QD-0212A/115-1
Will the bumper brackets on a 98 malibe support the weight og towing it with towbar behind an rv/trk or do i have to buy a base plate.im trying to keep costs down
I would not trust the "Bumper Brackets" in this case. I own the same year and model that you do (1998 Malibu). Those brackets are designed to hold a rather flimsy ABS plastic bumper, NOT to handle the entire weight of the vehicle. Is there anyway you can attach the towbar directly to the Frame? That's where you would want it as the Frame will support a great deal of weight. Hope this helps.
Aug 31, 2010 | Chevrolet Malibu Cars & Trucks
How do I remove the ignition lock cylinder from a 2003 Saturn Vue for rekeying?
REMOVAL
  1. Disable SIR system. (Refer to "SIR Disable/Enable Procedure (For Frontal and Curtain Inflators)".
  2. Disconnect negative battery cable.
  3. Remove lock cylinder bezel from steering column shroud by carefully prying with thin blade screwdriver.
  4. Remove shroud fasteners and remove steering column upper and lower shroud panels.
  5. Insert key into ignition lock cylinder and rotate to RUN position. Then rotate ignition cylinder back to ACC position.
  6. Depress locking button on side of ignition module assembly with a thin pick-type tool. Slide lock cylinder assembly from ignition module.
INSTALLATION
IMPORTANT: Actuator blade within ignition module housing must be in ACC position to install lock cylinder assembly. If rotated, replace it to ACC position, using needle nose pliers.
  1. Insert key into ignition lock cylinder and install into ignition module.
  2. Install steering column upper and lower shrouds and shroud fasteners.
  3. Install lock cylinder bezel.
  4. Connect negative battery cable.
  5. Enable the SIR system. (Refer to "SIR Disable/Enable Procedure (For Frontal and Curtain Inflators)".
Apr 07, 2010 | 2003 Saturn VUE
Can I install the unit in the window sideways?
Not really unless you can divertthe hot air from the back side to the outside and and the cool air and intake to the inside, you could do it with some clear tape and some plastic sheeting , but better to build a frame to hold it outside facing in two L brackets then tape it up with some thick plastic.
Jul 23, 2009 | Heating & Cooling
A/C Unit Pushed too far into window??
it's better to put a supporting frame under these for a variety of reasons, not withstanding your neighbors sanity and well being.
Jun 03, 2008 | Haier 539490003 Air Conditioner
Installing
Turn the curtain and bracket so when mounted to the ac the window will close behind it. Hope this helps. Thx RepairUSA
Jul 30, 2007 | Goldstar R5050 Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
100 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Bill Jennings
Bill Jennings
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
