Question about LG LS-K2430HL Heat Cool Mini Split Air Conditioner
Cond.fan or Compressors works separately on coollingmain pcb replacedstill same.making cond.fan connection directit is working but does'nt cuts off
    Problem Solver:
  • 11 Answers
You need to replace the board, and reconect the fan the correct way.
Posted on May 21, 2010
Problem with 2006 e150 van. air cond. cuts in and out in all fan modes. iam getting cold air and the fan modes sound right. please help me, dan
You mean the compressor cuts in and out? All compressors do this if the vehicle is cold enough it shuts off, also if the pressure of the freon is too high or too low it will shut off.
Nov 12, 2016 | 2006 Ford E-150
Can you help me to fix refrig
the condenser needs cleaning or the cond fan motor is not running.... remove the front grill located on the bottom of unit next to floor, you can see the cond coils from there, you should also be able tell if the fan is running, it is located in the rear of unit,, remove the cover behind ref at bottom to access the cond fan motor....
Oct 09, 2014 | Haier Refrigerators
Kegerator not cooling
which fan , inside or out.. if outside condensor fan is running then it has a bad 175 capacitor or if the compressor is running then it is low on refrigerant. if the cond fan is not running then check thermostat.. you can do this by connecting the two wires together.. another way to check the compressor, cond fan is to reach under and unplug the wires going to comptessor and plug into a 12ga extention cord.
Nov 17, 2013 | True Direct Draw Systems: Kegerator...
The refrigerator part is 60 degrees and the freezer part is blow 20 degrees, I found the cond fan motor locked up not running, I have cleaned the condenser coils, replaced the cond fan motor but the...
Please follow these steps.
Keep temp setting at 5 degree. Check defrost timer, thermostat and frost heater are working properly. Call repairman to check above all. Thanks.
Feb 02, 2011 | Admiral 26 cu. ft. Side-By-Side...
Compessor is running hot, fan is not running
need to know brand and model. which fan was replaced ( evap or cond ) . if evap fan it may be the door sw as some model only run fan wth door closed. if it's the cond (fan) motor then ck wiring at compressor . or borken wire. in or about the compresser area .. hope thes help . mm
Jul 05, 2010 | Refrigerators
Condenser Fan not working when the Air Cond is On.
There is a high pressure switch on the high side of the ac system,it most likely is bad.
Apr 06, 2010 | 1996 Mercedes-Benz C-Class
The fan on my new GE Air Cond. will not stop
I opened and checked the online manual where I found the answer.
Nov 01, 2009 | GE Heating & Cooling
Return air duct frozen over
check to see if the evap fan is running inside freezer.
clean cond coil under back of fridge.
check if evap coil inside freezer is froze over, if fan is running and cond coil is clean, it may need a defrost timer.
Sep 24, 2009 | Refrigerators
Refrigerator is not cold or freezing in freezer.
the gurgling sound is normal, its the freon inside the evap. .the compressors also runs at a very high temp. , there is only 1 fan that circulates cold air, there is another fan but it is the cond. fan which blows hot air located at the bottom near the floor
May 06, 2009 | Refrigerators
LG LS-K2430HL Heat Cool Mini Split Air Conditioner Logo
137 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
