Question about Troy-Bilt Pony Garden Tiller
Trying to reolace battery in troybilt pony tiller
Trying to reolace battery in troybilt pony tiller 5 years old need battery #/size
5 Suggested Answers
SOURCE: I need to know my Pony Tiller model number it is
look on the trans case on left side if you are standing behind the tiller'. other numbers are on the engine cover serial number ,engine size. looks like htis H35-4556n-ser. 2071B on engine cover. number on side of trans case will look like this 500 30 12-82 BF 2 . 12-82 is the year it was made
Posted on May 17, 2009
SOURCE: Where is the model number on my troybilt rear tine tiller?
If it's as old as mine (circa 1976), it's stamped on the casting right below the T-handle that allows the handle bars to pivot (also the gear case fill cap)
Posted on Mar 29, 2010
  • 8404 Answers
SOURCE: I have a troybilt pony tiller made on 1/22/79. On
One is a serial number and the other is a part number ... This tiller was built in Troy, New York by Gardenway Manufacturing. Unfortunately, that family owned company is out of business. Whether there is still manufacturing in Troy New York, I am not sure but it is not the same company today as it was in 1979.
The assets, including the name, were purchased (and some sold) by several manufacturers, notably, MTD. The Troy products sold today are similar to the Troy products of the Gardenway Manufacturing. In my experience, there is no better customer service than that I received from GardenWay. The 6.5 was a big Pony ... I purchased a Horse about the same time and it is a 6.0 hp Techumsa. I am on my second engine and I wouldn't take twice the $ for it.
This tiller probably cost in the vicinity of $800.00 delivered.
There is a company in Canada that has specs on most Troy Models ... and access to lots of Troy parts, though thre are lots of other places that sell parts and have diagrams as well.
At one point Briggs was making 'flails' for the Troy Chipper Shredder ...
I hope this helps you with your tiller ... It is a teriffic machine.
Here is an interesting discussion board ... if you are interested: http://forums2.gardenweb.com/forums/load/tools/msg1108413014912.html
Thanks for your interest in fixYa.com
Posted on Jun 29, 2010
  • 26 Answers
SOURCE: I have a 5 hp troybilt pony tiller. The axle seals
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in PONY for your model number and find your operator manual by your serial number. The operator manual should have detailed instructions on how to replace your seals.
On the Horse model you remove the wheels and then carefully use a couple of screw drivers to pry out the old seals being careful not to scratch the wheel shaft sealing area. Then polish the wheel shaft with fine emery cloth to remove any sharp edges. Then grease the wheel shafts and carefully slide the new wheel seals on and use a piece of plastic PVC pipe cut square that will slide over the shaft and gently drive the seal to the depth the old seals were installed at. You dont even have to drain the gear oil. Getting the wheels off the wheel shaft is sometimes a problem if they are rusted on. if you can get the wheels off its not to hard to change the seals.
Frank
Posted on Oct 07, 2010
Troybilt Rototiller. Most likely the Pony model. Tiller is about 50 years old. Belt slips. I put on a new belt last year. Is there any adjustment of the pullies to tighten the belt?
On the engagement lever where it locks in.The lock block will wear on the bottom or the engagement lever gets bent.What we did was weld a brace to the engagement lever and maybe a little build up on the block where the wear is.
May 08, 2011 | Garden
I am currently looking at buying a troybilt horse with serial # 340455. Can someone let me know what year this is?
That tiller was made sometime between 7/1/78 and 1/1/79. This is the Horse II model and is a four speed one belt tiller. The Horse I was a two speed two belt tiller. These are very good tillers if they have been reasonably taken care of.
Frank
Sep 30, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a 5 hp troybilt pony tiller. The axle seals need replacing can you describe the best way to replace them. This tiller was built in Feb. of 1990.
Frank
Sep 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Mar 28, 2010 | Troy-Bilt Pony Garden Tiller
Can i see the models from 1983 to 1985,i need a belt so i can use reverse again but i dont now my model or size. my husband died 3 years ago. if i could see some pictures from the 1980's mine has a potatoe...
Your question doesn't give enough detail to properly answer. Do you know if the tiller is a Horse model or a Pony model? Troy Bilt made both models back in the timeframe you noted. The Horse model had tires that required air to inflate. The Pony model likely had hard rubber tires in that era. The Horse models had a reverse disc, no belt. The Pony had a belt.
Once you know which model you have - look for your closest Troy Bilt dealer and see if they can track down the part for you. They might appreciate it if you could provide the serial number - which is located on the pipe connecting the tiller transmission front half to the back half, where the tines are located. It's stamped right into the metal tube on both models.
Jul 17, 2009 | Troy-Bilt Garden
Troybilt pony wont go into drive.
Not technically a solution, but there are Troybuilt tiller forums out there on the net. MTD bought them out some years back and some parts are still available. I had to go thru them to find a part number for a mid 80's Horse unit that had a broken drive coupling. Anyways, they have parts breakdowns and manuals on their site. And I've seen some on ebay if you need parts.
Jun 01, 2009 | Troy-Bilt Pony Garden Tiller
I need to know my Pony Tiller model number it is several years old. It has a B&S moder number on it.
May 11, 2009 | Troy-Bilt Pony Garden Tiller
Troy-Bilt Pony Garden Tiller Logo
184 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
