Question about Phonic Power Pack 620 PA Package System
I have a phonic pa system that just stopped working. I had the fuses checked and they check out fine. The night before I was getting what sounded like a lot of static from the speakers. Any ideas?
3 Suggested Answers
  • 3 Answers
SOURCE: power amp for pa system stopped working
Sounds like you have a power supply problem in the amp. I am assuming the fuse you are replacing is intergraterd into the AC connection. You need to dig deeper. If you are not an electronics person you will need a tech.
Posted on Jul 02, 2010
technical114
  • 1851 Answers
SOURCE: Phonic S715 "15" 2way
This speaker is not an active one. This means that it hasn't integrated amplifier, so you need an external one. The cable from the amplifier goes to the speaker. Remove the woofer in order to get access at the inner parts and check these points:
  • In case that there is a crossover present there must be a burned out coil or capacitance
  • In case the cable from the female jacks at the back panel goes direct to the woofer, there must be the woofer destroyed or the cable disconnected. Check the cables, it's less expensive than to replace the woofer.
Post me back if there is a crossover in use or it is direct connected and any other points of interest you came up, in order to guide you further.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on May 25, 2011
Phonic max 860
Check your speaker wiring, looks like you have a short somewhere and the amp is going Thermal. Use a tester, if the cables into the amp read below 4 ohms you are in overload. Blessings...
Aug 15, 2014 | Phonic Audio Players & Recorders
I have no sound
you should open it and look for burnt components like capacitors. they can usually be replaced.
Jun 23, 2014 | Phonic Powerpod 410/S710 Pa Package
I need schematics for the Phonic 620 powered mixer
I am repairing the same one. Repaired the power supply full bridge rectifier and 15 volt regulator then tried it and the music starts for 1 second before some relay (protection?) disconnects and the music stops. So decided to get the service manual from here - just checking out now, it is for the fan cooled version which is probably the heatsink version I'm working on.
http://elektrotanya.com/phonic_powerpod-620-plus-v1_sm.pdf/download.html
Jan 28, 2013 | Phonic Power Pack 620 PA Package System
Thanks and regards
Stelios
May 25, 2011 | Phonic S715 15 2Way PA Speaker
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
Power amp for pa system stopped working
Jul 02, 2010 | Phonic Power Pack 620 PA Package B-Stock...
Radioshack 250 watt pa amp stopped making sound
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Nov 14, 2009 | Radio Shack 250 Watt PA Amplifier...
91 people viewed this question
Top Phonic Audio Players & Recorders Experts
Greg Cann
Greg Cann
Gil Shultz
ray gallant
Are you a Phonic Audio Player and Recorder Expert? Answer questions, earn points and help others
