Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Need to reset the keypad on my garage door opener
    President:
  • 3,197 Answers
Locate the smart/learn button near where all those white wires go on the back of the motor unit. Press and immediately release this button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Posted on May 17, 2010
Reset garage door opener and it won't open or close now
What was the reason that cause the need to reset the opener in the first place? What reset procedure did you perform?
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Keypad won't program to garage door opener, tried several times, keypad easily programs to 2nd garage door of 3 car garage, but not to main garage door. Need main garage door to open with keypad. Changed...
It sounds like the keypad is not compatible with the main garage door. Make sure the keypad is the correct only for that model number opener. Older models will not work with newer openers and vice versa.
Oct 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need to reset code on chamberlain garage door opener.
The only code you can reset is the code for the keypad. To do this you need to:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Sep 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
To change the code you need top locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
Mar 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need to know how to reset keypad for garage door.
If you pressed and immediately released the smart/learn button and then walked over to the keypad and keyed in a 4 digit code and it doesn't work then the keypad is bad. The model number for the opener is on the door side of the motor unit and starts with 139.
Mar 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need to reset my garage door opener
You will have to erase the memory which means you will have to reprogram your remotes and keypad if you have one.
To do this locate the smart/learn button on your motor unit just to the left of all those white wires. Press and hold this for about 6 seconds. The only thing that should work is your wall control.
To program your remotes press the button on the remote and then press and immediately release the smart/learn button. Do this for each remote you have.
To program a keypad press and immediately release the smart/learn button, walk to your keypad and key in your 4 digit PIN and press enter.
You should be good to go.
Aug 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keypad code will close the door but not open it.
check that both codes (in the remote & garage door opener) are the same. Press reset on the opener and reset enter the code.
Nov 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
To reset the keypad you have to also reset all the remotes. on the back of your opener there is a square button, press and hold the button untill the lcd light turned off then press the button once and press your remote buttons repet untill all the remotes are set. Then press the button place your code on the keypad and press and hold enter untill you hear a click or the lights flashing and your set.
Aug 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
151 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
