Question about LG enV VX9900 Cellular Phone
Lg env VX-9900; the charger works but when I plug the charger in it does not charge? The phone works and is turned on but will not take the charge.
TanyaAD138
  • 77 Answers
SOURCE: Garmin Nuvi 7700 bluetooth to LG enV-VX9900
You don't. This phone is incapible of that as it's a VZ nav. capible phone. Sorry.
Posted on Dec 31, 2007
Buschchris1
  • 474 Answers
SOURCE: My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Posted on Mar 25, 2008
SOURCE: Env help plz
The reason the phone won't charge is because the internal power port pins are broken off of their solder joints to the main board inside the phone. Wiggling it helps at first because the pins can still touch their connection points but after a short time that will cease to help. Google "cell phone repair". It usually cost around $50 to get it fixed with a new power port installed. Turn-around is usually 2-3 days.
Posted on Nov 02, 2008
SOURCE: My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Posted on Sep 23, 2009
SOURCE: how do i transfer pictures from my envy phone to my pc
If you have a bluetooth adapter for your PC, connect your phone to your PC using bluetooth. Then go to my pictures in your phone. Hit the options button and go down to manage my pics. Select which pictures you want to send. Hit the button that says send (not the one next to the end key but the long silver key at the top left of your keypad) and go down to the option that says via bluetooth and select it. Your pictures should then be sent to your PC. BTW this is for the env2. I'm not sure if it works the exact same way for all env phones but it doesn't hurt to try it.
Posted on Dec 14, 2009
How do you fix the charging port on a lg 9900 phone?
You could have a charging port issue, you may need to install a new one into the phone or order a backup battery plus a battery charger, interchange them as needed.
Jul 15, 2014 | LG Pcmicrostore Brand Lg Env Vx 9900...
I need a manual to lg vx-9900
visit this link
http://docs.phonedog.com/lg-env-vx-9900-manual-4316.pdf
if it helps for you please give a 4 thumb rating.
thanks.
May 26, 2011 | LG enV VX9900 Cellular Phone
How I increase battery lifebon my enV
turn down the brightness to minimum required ,turn off anything unnesseary that you dont use as bluetooth ,Ir anyting like that, a trick use on my phone which seems to work atleast on my zte blade and my iphone 3GS is to connect the phone to the charger and let it charge to max then i restart the phone and connect the charger again for another hour and the batterylife seems to last one day more
Feb 21, 2011 | LG Pcmicrostore Brand Lg Env Vx 9900...
The people I call can't hear me on my LG Env VX 9900
With the phone OFF and BATTERY OUT.
BACK COVER OFF.
Pass a vacuum cleaner gently over the MIC for two minutes.
A small paper clip can be use to assist removal of dust and dirt.
DO NOT PUSH paper clip or any object inside.
Inspect for dis-mounted item inside the phone.
Re-insert battery and cover.
LG Env VX 9900 is the best music and simple video phone.
Do this clean up around the lower MIC portion will keep the sound quality is check.
Jan 24, 2011 | LG enV VX9900 Cellular Phone
My phone is lucky by the sos code
really yes! this phone is a lucky one, because
this is a refurbished LG enV VX-9900 phone ready for activation on the Verizon Wireless network ,their will be no need of sos code for activation
thank you
Dec 26, 2010 | Verizon Communications LG enV Cell Phone -...
Need a user Manual for my LG vx 9900 Cell Phone
Click on this link Lg vx 9900 User Manual or
to download the user manual for your Lg Mobile. This is a direct link, download will begin once you click the link. The file is in pdf format, so you'll need a pdf reader to read the manual. If you need one (click here to download adobe pdf reader)
Good luck.
Thanks for using FixYa.
Jul 29, 2010 | Cell Phones
LG enV VX9900 Cellular Phone Logo
51 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
