Question about Kenmore 73952 Gas Dryer
Need help with gas dryer Kenmore 90 series serial
Need help with gas dryer Kenmore 90 series serial #MK0211114 the gas does not ignite electric is working fine
  • 10,319 Answers
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
Posted on May 18, 2010
2 Suggested Answers
marka19
  • 1430 Answers
SOURCE: need help with gas dryer Kenmore 90 series serial
This could be several things thermal fuse,hi limit thermostat,flame sensor, ignitor,or coils. There is a video on troubleshooting a gas dryer at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting procedure. It is a different model but troubleshooting will be the same. You could also check the video on the electric heating element replacement that is a kenmore 90 and most of the parts will be the same. That one will give you a good idea of what thermostat is what.
Posted on Mar 24, 2010
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
Mar 24, 2010 | Kenmore 73952 Gas Dryer
Kenmore 70 series gas dryer (Whirlpool model) will not ignite!!!!
>> Do you know where the flame sensor is located? I figure the ignitor is where the "glowing" occurs and the gas line feeds to. Thanks for your help!<<
The flame sensor is right next to the ignitor. Also see this link for what it looks like:
http://www.apwagner.com/index.php?main_page=index&cPath=7_96
Mar 18, 2010 | Kenmore 73952 Gas Dryer
My Kenmore 90 series dryer's pilot light is out. What can I do? I have a Kenmore 90 series gas dryer and its not getting heat.  If I look at the igniter which is a carborundum igniter and I don't see...
Hi, You should first check the fuse. If the back comes off try this:
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If the rear panel does not come off, please get me model # and I can assist you further.
Please let me know if this helps you.
Thanks
Vic
May 28, 2009 | Dryers
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
How to light the pilot for gas dryer, 90 plus series
Dryers haven't used pilot lights in over 30 years. You have an electronic igniter
Jan 16, 2018 | Kenmore 74602 Gas Dryer
Kenmore 73952 Gas Dryer Logo
330 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
