Question about Philips Magnavox 42MF521D/37 Television
Blue led is on solid no blinking but no high voltage on vs va vscan vset and ve test points. the three buffer boards were replaced after being blown. but still no pictureboard number is lj44-00092e
  • Philips Master
  • 5,807 Answers
Hi
jshea1959,
blue led is on solid no blinking but no high - thumb_lj44-00092e.jpg LJ44-00092E SMPS Power Board
LJ44-00092E SMPS POWER BOARD (CBA SMPS)
These are links in which you can choose to :
a ) have it repaired
http://www.moduslinkptstvboards.com/LJ44-00092E-P11466C13.aspx
b ) DIY repair
PHILIPS MAGNAVOX Plasma Repair Kit for LJ44-00092E
http://cgi.ebay.com/PHILIPS-MAGNAVOX-Plasma-Repair-Kit-LJ44-00092E-/130391338223
c ) replaced
Philips 996500039214 Power Supply Item #: sj-996500039214
http://www.shopjimmy.com/philips-996500039214-power-supply.htm
Have a check also on the board for IC561( TO-220-4R package ),
50V 47uF cap
should you need to look for possible bad component
it may look like these:
Hope these helps,
regards,
palaboy
Posted on May 20, 2010
  • 8 more comments
  • Rommel Cana
    Rommel Cana May 21, 2010
    these may looks like the board , you are having:
  • Rommel Cana
    Rommel Cana May 31, 2010
  • Rommel Cana
    • Adjust your solder tool so that a temperature around 360°C
    - 380°C is reached and stabilized at the solder joint.
    Heating time of the solder-joint should not exceed ~ 4 sec.
    Avoid temperatures above 400°C, otherwise wear-out of tips will rise drastically
    and flux-fluid will be destroyed. To avoid wear-out of tips, switch “off”
    unused equipment or reduce heat.
  • Rommel Cana
    Rommel Cana Jun 29, 2010
    Additional Info:
    From the table below, ( these can also be found labeled on the panel
    chassis )
    You may need to start measuring voltages from the Preconditioner ( VS )
    then the VA voltages to Vscan to the right of the guide.
    You may need to have:
    a Multimeter
    How to use a multimeter
    And a lot of patience
    How to test for Continuity
    How to solder boards properly
    How to test MOSFET
    Here are some of the schematics :
  • Rommel Cana
    One possible cause is the PWM Generator ( oscillator )
  • Rommel Cana
    Rommel Cana Jun 30, 2010
    • here is additional info on :
  • Rommel Cana
    continuation:
  • Rommel Cana
    7610
  • Rommel Cana
    Rommel Cana Jul 02, 2010
    • additional info:
  • Rommel Cana
    additional info:
  • Philips Master
  • 12,061 Answers
Download.p4c.philips.com/files/.../42mf521d_37/42mf521d_37_pss_aen.pdf
http://www.eserviceinfo.com/equipment_mfg/MAGNAVOX_2.html
www.scribd.com/.../Philips-Training-Manual-TV-Plasma-Display-Panel-Chasis-FTV1-9 -
www.scribd.com/.../Philips-Training-Manual-TVHD-Chasis-L05HD -
www.scribd.com/.../Philips-q528e-Service-Training-Manual-Part2 - 22 hours ago -
At top link is your user manual, below that are a pair of service and repair manuals, below them are some training manuals so you can better understand how it all works. Please get them all they are very valuable resources. And, well I applaud you for wanting to have a go, but you must make sure that you are starting in the right place, That is The Power Supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. The Tools you will need are A SERVICE MANUAL a Good Multimeter, a Signal generator, a Signal Tracer, pref an Oscilloscope, Soldering Iron, De-soldering iron, Probably, too, A SMT Hot Air desolderer (for the Surface Mount IC's) Air, An Anti-Static Wrist Strap, (MOST IMPORTANT, to prevent ESD), Cutters, Screwdrivers, sometimes, Torx, drivers too. Tweezers, are real handy, magnifying glass or eyepiece, a good strong Light. OH and you MUST have the original remote control too, as one needs this to "Program" the Computer in the TV, after, and during servicing, and to be able to put the TV, into "Service Mode" too.
So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, Philips, in your case, i recommend you contact a local or head office and ask for a referral to an authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on May 16, 2010
  • Joseph Shea May 16, 2010
    I have tried all the links and none worked most ststed the file or doc was not found on this server. What next. my model number of the set is 42mf231d/37b the boards replaced were lj92-01203a or lj41-02761a lower y buffer board which had a fried ic on it which burnt two surface diodes numbers d5018 d5009 resistors r5090 and r5028 these are on the lj92-01200a or lj41-02759a board both were replaced but the high voltages which fire the screen are not there but the low voltages are. my service manual is incomplete it is a early printing giving no info on the pdp and no parts list. there must be a newer printing avail. mine is in pdf format. i am using the 42pf5321d.pdf version from philips. i do have most all the test equipment you suggested. my scope is 40mhz dual trace i dont have a signal gen or tracer
Samsung television problems
Hi Jeff, Will you please let me know whether the red LED, lights, blinks or it is simply not glows at all. Thanks.
Dec 23, 2013 | Televison & Video
Sound no picture Samsung 58" Plasma TV Model #: PN58C550G1FXZA
if you are a tech in any aspect, try testing the power points Vs and Va voltages. If not present even with the other circuit boards disconnected the Vs is supposed to be 205v when disconnected like on my tv, it only had 12v and the Va which is supposed to read 56v was reading about 10v when the boards were connected (Y Buffers). With the boards disconnected the power supply will read high voltages, and when connected (try lower first, then try upper, then try together). If there is a voltage drop (significant) that particular board connected is the culprit. If the PSU doesn't read a large voltage like mentioned, try replacing the PSU first. Go to www.shopjimmy.com for parts
Nov 26, 2012 | Televison & Video
May sony tv has sound when you turn it on but no picture
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 23, 2012 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Samsung PS42D7HD plasma TV has no pic no sound. Vs, Vg, Ve, Vscan, Vset volts are all correct. Heat sinks on X & Y boards are warm to the touch. RF In source and A/V In source have no output sound or...
Take your scope and see if you have any activity on the LVDS cable on the main digital board as you press the menu button or the menu on the remote. If you do not see anything then replace the main board. If you do then the plasma display panel is probably bad. Time for the bone yard.
May 08, 2011 | Samsung Televison & Video
What are the Vs Vscan Vset and Ve dc voltages supposed to be for this tv. i know they are posted inside the tv, but i amd experiencing some blue pixels in the screen. found others to be fixed with a...
They mean... Vs = usually to do with Volts, usually denoting Vss, or Ground... Can also mean Voltage on the Source of a FET transistor. Vscan, = Scan Voltage. Vset, = Set the Scan Voltage, Ve, = Voltage again usually Vce meaning Positive Volts,. Can also mean Voltage ON the Emitter of a Transistor. But unless one can see the place in the circuit on the schematic, it is hard to tell.
Feb 25, 2010 | Philips 42PF9631D 42 in. Plasma Television
Plasma screen flicker
If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 21, 2017 | Televison & Video
RE: Dell W4201C
a few things, on checking the ground, are you sure you have a good connection (try scratching or pushing harder with your probe tips) to ensure that is 0v they should all be reference gnd which is 0v
did you know that there are two (2) power supplies? This set has a power and sub power supply, did you check both?
I tried to look at your posted pic, but that site blocked your image (no hotlinks allowed)
Jul 29, 2008 | Dell W4201C 42 in. Plasma HDTV
Philips 42PF9630A 42 in. Plasma 42 in. Plasma
Ok 7 red blinking led, remove the back cover of the TV. Looking at the power supply in the upper left of power supply. If everything is working fine you will see a solid green led if there is an error, you will see this light blinking also. Right below this led on the power board you will see a list of numbers 1-13 this will give u the problems that this led flashing problems are. More and likely u will have a problem with VSET or VSCAN. Which is connected to the Y-Main and Y-buffers,( the board that is too the left of the power supply if u look on the small print on this board you will see that it reads. 42HDV4 Ymain and the 2 small boards connected to it are Y buffers. To be sure that this board is bad if the TV keeps going into error protection. unplug the power supply and wait for the led to stop flashing. Disconnect the cable that plugs into Y-Main from the Power Supply. It should stay running. If u remove this board and look underneath u should be able to see where this board is getting hot. Easiest fix is to order a replacement. Y-main assembly.
May 05, 2008 | Televison & Video
Relay click and 9 blinking led.
Try the following steps:
1. Remove the power supply to X Main board, check VE. If you get normal VE then replace the X Main board. Otherwise to 2.
2. Remove the power supply to Y Main board, check VE. If you get VE then replace the Y Main board, otherwise to 3.
3. Replace the SMPS board & SMPS 200V board.
Good Luck
Mar 22, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung HP-R4252
Just check the voltages and refer to the sticker on the back of the panel (inside) Should read VA, VE, VS, VSET, VSCAN, VSUS,VSUSTAIN, ETC. And see which ones are missing then write them down and we will go from there. See if any fuses are blown as well. Just check those on the Ohm check. Or diode check is handy as well for this. Let me know if i can assist further. GURU JAY
Feb 06, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Philips Magnavox 42MF521D/37 Television Logo
1,442 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
