SOURCE: clarion 6 cd changer cassette will not eject
Don't waste your money and buy those repair manuals. There is an easy fix for this. The rootcause is most likely related to your disc tray (crooked carrier or broken spring). Just get a small screwdriver and take out the two black srews of the inner faceplate, covering the cassette tray itself. Please make sure you do not drop those tiny screws. Use a magnetic tip screw driver. Take the faceplate off. You will see a litlle lever in the center. Just push it aside and your cassette will pop out with no problem. That simple. So don't waste your money!!!
SOURCE: 6 cd changer
try to reset the cars computer. i had the same problem and it fixed it. all you need to do is unplug the battery for about 10 minutes and it may work. Good luck!
SOURCE: 6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
SOURCE: cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
