Question about Olevia LT32HVE 32 in. LCD Television
Olevia 37" lcd, channel won't change and more
Got my TV a few months ago - new. Channels, sound, etc completely stop responding to the remote. I can't even change the channel or volume by pushing the buttons on the actual TV. I have to unplug it to "reset" the TV to respond to the remote again. This happens often.
  • Anonymous Aug 18, 2008
    I have the same problem. The only thing that helps is to keep the remote covered from light-somehow this causes it.
  • Anonymous Mar 21, 2009
    I have the same problem. I'm afraid its a computer board problem. I managed to get the menu to work and reset to factory settings but still the same issue.
SOURCE:
  • 3 Answers
SOURCE: RCA REMOTE CONTROL CODE FOR OLEVIA/SYNTAX 237 HD TV
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control all the functions on both the Olevia TV and the RCA Satellite box, except the A-B-C-D buttons for the User Guide. It's codes are:
Satellite Box - 00392
Olevia TV - 11610
Enjoy!
Nick from Ft Myers
Posted on Mar 08, 2008
  • 4 Answers
SOURCE: static electricity damaged my t.v.
I think this model has a timer on it, it seems to go when the warranty runs out, not proven but Mine went out about a month ago. My only fix is to plug my tv (via the service port which is COVERED) to the usb port on my computer using my BlackBerry usb cable, in other words the Mini USB. Seemingly I must be logged on to do so and wait for the Chime form my pc, a balloon will pop up for new hardware not recognized (vista) then press the power button and then it turns on, unplug the usb cable and make sure the source is set to tv / video or else it will power back off and you will have to start all over. Theres NOT A PERMANENT fix yet but this is what I do every time I want to use the TV, I have a laptop so I use it as the Monitor just to watch movies. If you have a desktop I recommend keeping the cable handy BUT DO NOT LEAVE THE USB CABLE IN FOR LONG USES. THE SERVICE PORT IS COVERED FOR A REASON!!!
Posted on Apr 09, 2008
freetek
  • 5569 Answers
SOURCE: Olevia 242T 42" LCD HDTV - Suddenly No Picture, Nothing Works
 I heard they were restructuring their company or something.
There has been a change ownership from Syntax-Brillian to Olevia International Group.
Details of Olevia brand
Unfortunately for all of us (we have 747i) service seems very poor and the failure mode you describe doesn't give me any clues despite 40+ years of service experience.
Ours is still 100% but I now suspect our trouble will come.
Posted on Nov 28, 2008
  • 362 Answers
SOURCE: Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly? If so i would think you have a remote problem. If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 09, 2009
MNfisherman
  • 11896 Answers
SOURCE: need a logic board for a olevia flatscreen tv, but can't find
Most of the new TV's display a blue screen when there's no signal for it to lock on. Try unplugging it for about 5-10 minutes and see if that clears up the problem. Why? Because they have microprocessors in 'em (computer chips) and just as like with any other operating system, they can hang up or crash. This isn't an uncommon problem with today's TV sets. Unplugging it for awhile resets the microprocessor (in other words, it causes it to re-boot when you plugit in again).
Also, try connecting a vcr or dvd player up to it and see if there is any difference.
Lastly, this could be caused by the power supply or a fuse inside which has gone bad and has blown
Posted on Jan 17, 2009
Why won't my TV scan for channels
Possible causes for this are:
-your tuner is broken
-antenna cord is not connected correctly
-does your tv support your source (cable, sat, etc...)
it is a bit old model so you may need a setupbox to tune the channels.
If you can pin point the problem it seems that ebay has a lot of spare parts for that model.
Aug 18, 2015 | Olevia 37" 237-t11 1080i widescreen hdtv...
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Olevia lct tv can't do a channel auto scan
first check the batteries in the remote to make sure they are not low and then have the remote tested most repair shops do it free.
Mar 14, 2012 | Olevia LT37HVS 37 in. LCD HDTV
How do I get rid of "No Channels in list" mode
it happens when we have already used and set all the channel according to our choice and some whwere it happens when you dont have more channel to view in the television ,and may me some channels are locked ,you should go through your television manuals there is evry thing you want
Oct 30, 2010 | Olevia LT37HVS 37 in. LCD HDTV
I have Dish Network and remote #1 and 2...the TV for Remote #2 has now changed but the remote will not work...I replaced it with an Olevia Flat Screen (used one) 32in LCDHDTV Model 432-S12 but cannot...
If this hasn't been resolved, I do have some steps that will help you out. The link below will walk you through a power scan, which will program the remote to the tv. At that point, you will be able to change the channels on the tv with the remote.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Jul 14, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Where do i get olevia 537h firmware
funny things like channels changing of there own accord ,volume going up and down and other strange goings on are usualy down to the batteries in the remote no longer being of full strenght hope this helps
Jun 12, 2009 | Olevia 237T 37 in. LCD TV
I have an Olevia 23t lct hd tv. I am plugged in
you said you are using composite cables..? that means you have some kind of cable box ? if you want to get HD channels you have to use a HD box that is supplied by the cable company.. the HD cable box then has to connect to the tv with component cables (green,blue, red cables) or HDMI cable.. to send the HD signal to the television.
May 13, 2009 | Olevia 237T 37 in. LCD TV
My Olevia TV will not change channels using the remote or buttons on the TV. When I push the channel up or down button, the tv mutes. It will change to 1 channel using the return button. I have tried...
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
Apr 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT32HVE 32 in. LCD Television Logo
153 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
