Question about Royal VF1012mx Shredder
Need plastic gear for vf1012mx - Royal VF1012mx Shredder
    Genius:
  • 1,218 Answers
Give Royal parts a call at 1-800-524-0799 they will be able to help.
Posted on Oct 06, 2010
A piece of junk mail from a religious organization had a "medalion" in the envelope. I put the whole thing in the shredder- royal VF1012mx. Now it is jammed makes a terrible noise.
Unplug the machine.
Remove the waste bin.
Remove 4 screws inside underneath to take cutting head off the basket/cabinet.
Turn the cutting head over and remove 6 screws that hold the top cover onto the bottom. Turn the unit back over and remove the top cover...remove the medallion if jammed...check the gear train to see if it has broken any teeth in the drive gears.
If you need parts contact Royal at 1-800-524-0799.
Jul 19, 2011 | Royal VF1012mx Shredder
MY ROYAL CROSS CUT SHREDDER VF1012MX WILL NOT ALLOW ME TO FED MORE INTO SHRED. THE MOTOR RUNS BUT THE BLADES DO NOT TURN. THIS HAPPENED AFTER IT JAMMED AND I REMOVED ALL PAPER.
Most likely broken plastic gear inside...open it up to see which one then contact Royal at 1-800-524-0799 for parts assistance.
Jan 16, 2011 | Royal VF1012mx Shredder
Need replacement gear
For Royal parts pricing and assistance contact Royal at 1-800-524-0799.
Dec 08, 2010 | Royal VF1012mx Shredder
Gears keep jamming
Unless the gears are damaged the gears dont jam themselv's....this is a cross cut machine have you ever oiled it.??? Put some lightweight oil on a sheet of paper and run it thro' the machine; do this a couple of times to start...if you use the machine a lot then do this once per week at least and only run the machine at about 70% of its rated capacity...less strain on the motor and parts and the unit will last longer.
Aug 06, 2010 | Royal VF1012mx Shredder
For parts availability and prices give Royal a call at 1-800-524-0799.
Mar 24, 2010 | Royal VF1012mx Shredder
Motor runs, but will not accept paper to shred
You say the motor runs...but can you see if the cutting shafts are turning???? if they are not then you have probably stripped a gear...open it up to determine which gear ( after unplugging machine of course.) then give Royal a call at 1-800-524-0799 for parts availability and prices.
Jan 17, 2010 | Royal VF1012mx Shredder
Teflon gear driven by the motor gear stripped on our VF1012MX crosscut -paper shredder
Give Royal a call at 1-800-524-0799;... they will help regarding parts availability and prices.
Sep 28, 2009 | Royal Office Equipment & Supplies
Shredder motor runs but gears are not engaging and will not take up paper to be shredded. Model is Royal VF1012mx
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
Jun 30, 2009 | Royal VF1012mx Shredder
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
VF1012MX Shredder
Call Royal at 1-800-524-0799 and describe part they can normally help.
Dec 27, 2008 | Royal VF1012mx Shredder
Royal VF1012mx Shredder Logo
101 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
