Question about Zoom H4 Handy Recorder
Distortion with Zoom H4 as Audio I/O to computer
I am using my Zoom H4 as an Audio I/O input to my computer and running Cubase LE. When I've been recording for about an hour and a half, I begin to have all recordings become distorted. The distortion goes in and out, but it ruins my tracks.
I've shut everything down for about half an hour, and started back up, which solved the problem. Is there anything I can do to get it to record regularly for longer than an hour or so?
Thank you,
Ryan Potter
  • Neptunian May 11, 2008
    Hi there. Yes I have a very similar problem, namely, I get distortion or perhaps more accurately - I get "static"- sort of white noise like you are between old style tv channels with the sound up. The infuriating part is that it's an intermittent problem so it's tricky to replicate it on demand. Needless to say my musical tracks are stuffed. This has occurred in garageband and audacity. I can't get the bundled cubase LE to even recognize the H4 as an audio input. I'm using a newish Imac 2.4ghz computer. Thankyou in anticipation.
Try using the power pack instead of batteries. Be sure to remove the batteries before using power pack, you can wreck the machine if you do not remove batteries. NEVER use the H4 on power pack while there is batteries inside.
Posted on Apr 06, 2008
  • haro_boy_69 Dec 13, 2010
    When using the H4 as an audio interface power is provided via the usb.
    I've had similar issues.
Hello I am trying to install CUBASE LE4 for usewith my Zoom H4n recorder but having diffultity getting the ZOOM H4 ASIO driver as mentioned in the setup guide. thanks pat
Hello Pat, you will probably have to download driver from the internet. I had a similar problem with another synthesizer software program. Even though the HD series Zooms come with cubase cds, they are not always compatible with the pcs. You should be ok after that.
Mar 23, 2011 | Computers & Internet
Getting mic setup thru cubase le 4
Make sure phantom power is enabled on the Tascam audio interface and you must enable the input in cubase that corresponds with the interface input on the track you are trying to record to.
Sep 28, 2009 | Tascam US-144 Sound Card
File import in 4-track mode impossible
Convert the audio to Mono WAV (16Bit, 44.1KHz). This can be done by using Cubase(Hope you got Cubase LE with Zoom). In an empty project import the audio, then mark the whole track using the Draw tool and then got to File->Export. Here select the above options and export. Import this file into Zoom H4 either by copying directly into the memory card or through connecting the Zoom to computer ( I copy it directly into the memory card's STEREO folder). Now if you import it to any project, it will appear there. You can now use Zoom H4 as a Karaoke device!! Anyway, sad that Zoom H4 doesn't support stereo tracks in the 4Track mode.
Aug 14, 2009 | Zoom H4 Handy Recorder
Connect to PC does not work
You need to upgrade the H4  firmware from Zoom website
http://www.zoom.co.jp/english/download/software/h4.php
You will need an external SD card reader.
Good Luck
May 06, 2009 | Zoom H4 Handy Recorder
I am trying to install the Zoom H4 with Cubase LE4. Can't
Sounds like it's time you upgrade to a core 2 or better computer.
Jan 06, 2009 | Zoom H4 Handy Recorder
Zoom H4: 1. the USB connection no longer works; computer does not detect the recorder. 2. the 1st input is too loud and distorted, so I cannot record through both simultaneously, as input one...
If you are using a Mac and have Leopard (sys 10.5) You need to upgrade firmware on the H4 from Zoom website
Good Luck
Nov 07, 2008 | Zoom Audio Players & Recorders
H4 randomly stops recording on cubase le
I may possibly have solved this. I didn't realise that when I log off from Cubase, the ASIO driver returns to the Multimedia ASIO driver, which seems to be the default setting.
Every time I want to record with the Zoom H4 in future I'll need to reconfigure the ASIO driver to the H4 one.
I thought once I'd set the driver, it would remain there every time Cubase booted up. Apparently not.
Aug 28, 2008 | Zoom H4 Handy Recorder
Distortion when recording flute on cubase
K, 1st of all... Try listening to the files directly from the h4, before download to the nbook. No dist? Problem solved.
Otherwise, note the mics are really sensitive, even in low gain, any "wind" instrument, like your flute, my clarinet, or even the voice can generate distortion.
solutions:
1. You have a "monitor" mode in the h4, just check for it, easy to find. Then you can adjust details on the h4, as you play and listen the output.
2.check the distance you are playing from the mic, be generous with that, anyhow you can move higher the gain. :)
3. Don't play directly to the mic, as the air from your instrument may generate a noise that is not a note, but simply air coming through the mic.
Monitor through computer... I'm stucked trying to make it work with any recording program in Vista, don't know how to make the system rcognize the device.So, I can't help you, and by the way, do you know how to record in Windows??
Luck bro
Jun 17, 2008 | Zoom H4 Handy Recorder
Transfering music from the H4 handy recorder to the pc.
Make the instalation of cubase LE that come when you buying the Zoom H4.When you instaled this,the driver H4 must appear in the sound/device properties.I hope you can solve
FF
Apr 06, 2008 | Zoom H4 Handy Recorder
Zoom H4 Handy Recorder Logo
154 people viewed this question
Top Zoom Audio Players & Recorders Experts
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
