Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
Posted on Jul 23, 2010
  • MGW801 Dec 12, 2010
    THIS DOES NOT WORK! I called Sears as well and they said they would NEVER recommend this after I explained what I read on line. In fact they would only recommend replacing the interior. I soaked my Wolf Oven for 3 days with wet bath towels and didn't remove a single spec.
    My amazing husband did have a solution - and it worked wonders. He restores old classic cars so he has had a lot of experience with different types of solutions. He removed all metal from our Wolf Oven (racks and pans).....he then put Pool Acid (found at any hardware store) all over the melted tin foil at the bottom of the oven and it quickly evaporated just the melted foil. He used a wet rag to wipe it out. Keep ALL your windows open and fans on (the fumes are strong!). We then polished the interior with a buffing cream and then wiped it clean again.....I am now self-cleaning my oven but before I started that - it all ready looked sparkling new again!
    I can't believe that we are the first to try this but I can assure you - IT DOES WORK!!! Saved me a ton of money replacing the entire interior to our brand new Wolf oven.
3 Suggested Answers
  • 1314 Answers
SOURCE: tin foil stuck to bottom of oven
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Posted on Dec 29, 2007
Skill Will
  • 53 Answers
SOURCE: tin foil melted in my oven.
hi floppy,
if you can't scrape most of it off with a plastic scraper, you may have to buy a new bottom pan. if you can get most of it off it should be ok to use. also if you have propane gas make sure your stove was converted properly.
Posted on Mar 21, 2008
try heating back up the oven then pulling it off be carefull not to burn yourself
Mar 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Tin foil melted and stuck to bottom of the oven of a Kenmorestove
It is safe.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 07, 2010 | Kenmore 33169 Gas Single Oven
Tin foil baked on the botton of a convection oven
Sparkle Toilet Cleaner,  Saturate  aluminum with it! contains hydrochloric acid, just eats it away until its gone , smokes a bit but does not harm enamel!
Oct 31, 2009 | Kenmore 33169 Gas Single Oven
Melted tin foil on oven bottom
in your owners manuel is stated to not put tin foil on the bottom of the oven.. depending on your model you may be able to replace the bottom panel.. however you can still use the oven without any problems.
Jan 20, 2009 | Kenmore 30169 Electric Single Oven
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You WILL damage the panel. The only option you have is to replace the panel or the entire oven liner...
May 20, 2008 | Ovens
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Tin foil melted in my oven.
hi floppy,
Dec 04, 2007 | Kenmore 33169 Gas Single Oven
Use "The Works Toilet Bowl Cleaner" to dissolve the foil. *Caution* when the cleaner is applied to the foil a chemical reaction occurs releasing some harmful fumes so please use outside or in a well ventilated area. I just did this to a Frigidaire oven I bought from Lowes at a discounted price. The previous owners bought it, did not read the owners manual or just disregarded the warnings on using foil in the oven and thought they would line the bottom pan with foil to help make it easier to clean (Good idea, but don't try it on the hidden element ovens). With the heating element being hidden under the drip pan the heat is hot enough to melt the foil and fuse it to the pan. Now most of the pans on these ovens are removable by just a couple of screws and I strongly recommend removing the pan when doing this. Squirt some Works toilet bowl cleaner on it in a well ventilated area and watch it go to work. It took about 15 minutes for it to dissolve all the foil on my oven, then I rinsed it clean and reinstalled it in the oven. The pan does have a slight discoloration on it, not from the cleaner but from the foil being melted onto the pan, if you choose you can buff this out. Most of the modern ovens have the ceramic coated drip pans in them so the Works toilet bowl cleaner will not harm them, unless you have scratched the finish off. Works Toilet bowl cleaner contains a fair amount of hydrochloric acid which is what makes this work so well.
Oct 23, 2007 | Kenmore 33169 Gas Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
857 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
