Laptop startup problem
Vista laptop refuses to start on reboot - says there is an error and when I ran repair, memory check and attempted to take back to last check point, no joy. I upgraded realplayer yesterday and have not rebooted since - otherwise no real changes to explain it. Any ideas very gratefully received.
  • JimDavies Mar 31, 2008
    Thanks for the suggestion - but I had fixed it going the F8 - Safe Mode reboot route - that enabled me to restore to a point when the system had been OK. Made sure I did a new back up as soon as I could though, just in case - and will increase the frequency of my regular backups to "daily" from now on!
    Genius:
  • 1,226 Answers
Hello.
You have a system error on the operating sytem. try reinstall the windows operating sytem this will resolve the problem. if not then maybe you should refpormat and reinstall the system. melnavz
Posted on Mar 31, 2008
  • Anonymous Mar 31, 2008
    happy for you. hope you will conrinue using fixya soon. please give good rating so that i'll be happy also like you.
    best regards, melnavz
6ya staff
SOURCE:
My son accidently shut his laptop down whilst installing microsoft office and now he has an error on startup: status: oxcoooooe9. I tried rebooting and starting in safe mode but it always goes back to...
Instead of re-installing the Operating System you can do an Operating System repair. Boot to the Windows Operating System installer disc,. If you have XP, boot to the XP installer disc then enter the setup program. There will be an option that says "Press R to Repair Computer". Press letter R then let the setup finish. For Vista/7, boot to the installed disc then select "Startup Repair" This will repair all corrupted Windows file and will keep your data intact,
Hope this help.
Mar 26, 2011 | Toshiba Satellite L305-S5908 Notebook
My Dell Inspiron 1525 freezes randomly after starting up. I can't use the mouse or keys to change the screen. The computer freezes around 5 minutes after starting up. I booted up in safe mode and have...
If you had no issue in safe mode the only thing I've seen like that is a virus that cuts of your use of I/O ports. boot into safe mode and try doing a system restore to a time before this problem occurred. IF that doesn't solve the problem try doing a clean install of the OS
Feb 28, 2011 | Dell Inspiron 1525 Notebook
My compaq presario f700 laptop says bootmanager missing when i tried the reboot cds its says cannot reboot from disc
Ifyour Windows 7 or Vista computer has encountered the dreaded "BOOTMGRis missing" error, you aren't alone. If the problem isn't hardwarerelated you can fix it with relative ease as long as you have a WindowsDVD handy.
If you don't have one, you can create a Windows Vista repair disk
http://www.howtogeek.com/howto/windows-vista/how-to-make-a-windows-vista-repair-disk-if-you-dont-have-one/
Boot off the Windows Vista DVD and then click Next at the first prompt You can also follow the step from this side:http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
The installation process will attempt to find your Vistainstallation directory. If there's more than one in the list, selectthe correct one and then use the Next button again.
Click the first link for "Startup Repair"
The installation process will repair the system, and then prompt for you to reboot.
Alternatively you could have chosen the Command Prompt option instead,and use the following command to fix the boot options only: bootrec /fixboot
At this point you should be able to reboot your computer, remove the DVD and everything should be working.
Nov 21, 2010 | Creative Labs Sound Blaster Live! Value...
Laptop wont start windows xp pro. goes to a blue
Take one memory stick out and test. Then do the other. Also checking each memory slot.
If not solved. When the computer starts, continually press F8 until you get startup menu- select SAFE MODE and fix the driver or software that is in startup
or
Roll back to last known configuration that worked.
While you are there- disable Auto Reboot on Failure.
May 02, 2010 | Computers & Internet
Bootmgr is missin cant start laptop
dint wory you are not alone in this problem and this ia a very easy to fix problem first you need to find a windows vista install boot cd
image15.pngBoot off the Windows Vista DVD and then click Next at the first prompt:
image16.pngYou should see a link in the lower left-hand side for “Repair your computer”
image17.pngThe installation process will attempt to find your Vista installation directory. If there’s more than one in the list, select the correct one and then use the Next button again.
image18.pngClick the first link for “Startup Repair”
image19.pngThe installation process will repair the system, and then prompt for you to reboot.
image20.pngAlternatively you could have chosen the Command Prompt option instead, and use the following command to fix the boot options only:
bootrec /fixboot
image21.pngAt this point you should be able to reboot your computer, remove the DVD and everything should be working
please rate this solution......
Apr 11, 2010 | Lenovo 3000 Y410 Laptop
Bootmgr is missing
If your Windows Vista computer has encountered the dreaded ?BOOTMGR is missing? error, you aren?t alone. If the problem isn?t hardware related you can fix it with relative ease as long as you have a Windows Vista DVD handy. . Boot off the Windows Vista DVD and then click Next at the first prompt: You should see a link in the lower left-hand side for ?Repair your computer? The installation process will attempt to find your Vista installation directory. If there?s more than one in the list, select the correct one and then use the Next button again. Click the first link for ?Startup Repair? The installation process will repair the system, and then prompt for you to reboot. Alternatively you could have chosen the Command Prompt option instead, and use the following command to fix the boot options only: bootrec /fixboot At this point you should be able to reboot your computer, remove the DVD and everything should be working.
Feb 20, 2010 | Compaq Presario CQ60-220US PC Laptop
My laptop as randomly started shutting down on its
Put you Vista DVD in the drive & boot off of DVD, and when you see the menu select Startup repair... leave it go on through it's process and reboot when told , this should repair your startup issue, otherwise get back to me.
Feb 18, 2010 | Compaq CQ60-215DX Notebook
Enter password
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!!
Note -- If your computer cannot boot into Vista even after repairs, then go back to System Recovery Options and run System Restore.
That's it! This is how you use Startup Repair for most unbootable situations.
Feb 22, 2009 | Acer Aspire 3680 Laptop
Problem(s) - Display, Memory... something?
Several things here:
-memory is not seated correctly
-the memory is defective
-mobo problems.
Try reseating the memory first and rebooting.
Try another stick of ram if available.
Let me know the results.
Jun 01, 2008 | Toshiba Computers & Internet
Open Questions:
Computers & Internet Logo
54 people viewed this question
Ekse
Marvin
Marvin
