Question about Makita 10" Dual Bevel Sliding Compound Miter Saw
Makita LS1013 Sliding Compound Mitre saw will not lock at chosen positions/angles on the turnplate other than the standard stop points. Turning the handle will not lock the turnplate anymore it used to it just moves freely now until it hits the nearest stop point. Does anyone know how to fix this ? Machine is 3 years old.
My saw had this exact same problem, here's how i fixed mine.
okay so here's a schematic of the saw
http://www.toolpartspro.com/image/LS...-Makita-PB.pdf
whether you have the exact same issue as my saw, in order to further investigate you need to get to the mechanism that locks the saw. To do this you need to take the turn base (140) off the foot base (156) . its really not too hard, just a little awkward setting the saw in different positions to remove the various parts.
Specifically on mine I had issues with the threaded rod (118) not screwing into the stopper holder (135). You'll see this part when you flip the saw upside down.
So to remove the turn base(140) from the foot base (156)....
Remove the kerf board (108) and under you will see a big bolt, go ahead and remove this. Then there are 4 more bolts which take off the guide rule (117), this what your piece of wood is put against when making the cut. Once these 5 bolts are out, the turn base can now be separated from the feet. Now you'll have a better view of the mechanics and see what is or isn't happening when you screw the handle to lock the miter position.
Part 136 (turn stopper) is what actually wedges to a pocket in the foot base which makes the saw lock. when you screw in the handle it actuates this part. make sure that is happening. I had to take out the threaded rod (118) and tighten it on a vice and work the stopper holder (135) deeper onto the threaded rod. use WD 40 to help it a long. You'll need to take off some other various parts to to get the rod out. this will be obvious once you have everything turned over.
Now that everything is apart you can blast it with some WD40 or what you think is best here. I used lithium grease. You'll see its especially important to lube up the pivot post that the 2 bases center on, (where the big bolt under the kerf board goes). also the slide plates (153) may be rusty, they'll fall out when you separate the 2 base plates. clean those up and spray them and anything else which will help with smooth movement.
the only important item to check once everything is put back together is the guide rule. this can be adjusted slightly in or out of square. Get a nice framing square and make sure your locked in at 90 (or actually 0 degrees on the saw) Sliding the saw the full distance of the cut on the square is ideal and maybe this was a good time to recalibrate that movement anyway.
hope this works.
Ben.
Posted on Feb 01, 2012
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Makita LS1013 Sliding Compound Mitre saw will not
there is a stop underneath the base that should put pressure on the table to lock into any position. I would unplug tool and turn over gently and look at the condition of the threaded rod which pushes the stop and the bracket that holds it. The stop itself could be worn or the rod might not be putting enough pressure on it. Also look at the cam for the slide to make sure the tube is not stuck inside it from applying too much pressure on it. You can remove it and "squeeze shut some and then I would reverse it" If the black knob has come loose and the hex nut has backed off the rod might not be long enough to hold the stop. You can go to Makitatools.com and download a breakdown to see what I am talking about. Let me know if you need more help.
Posted on Mar 25, 2010
How do I view the owners manual on line for a Makita LS1013 sliding miter saw
I have attached a link with the parts breakdown and the owners manual both in PDF format.
The parts breakdown should help you, if not let me know and I'll try to talk you through it.
Makita Products Tool Support
Mar 11, 2015 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Cornice mitre angle
Try this ... http://www.constructionknowledge.net/public_domain_documents/Div_6_Woods_Plastics/Partial%20Carpentry%20pdfs/Finishing_Roofs_NAVEDTRA_14044.pdf
Nov 25, 2013 | Makita 10" Dual Bevel Sliding Compound...
Makita L1011 compound sliding saw with sticky miter table
The LS1011 doesn't have a table angle release lever like the newer models so it's harder too swing the table from angle to angle, this also causes the plastic swing body to crack. Have you loosened the locking screw for the table? The table may have to be removed and the pivet shaft greased. I had this problem with an old Makita Table Saw 10" 2600.
Feb 01, 2013 | Saws
My Makita ls1013 has been having a problem running. It is not turning on at all. I just replaced the switch and it is still not working, I have checked and there is power to the switch. Please help
I would unplug tool and check the condition of the brushes. If they are worn excessively or burnt the tool won't work. Let me know what you find and I will try and help more.
Nov 16, 2010 | Makita 10" Dual Bevel Sliding Compound...
How do I remove the threaded rod from beneath the turn table of a Mikita LS1013 Slide Compound Mitre Saw ? I have removed the two black turning/tightning handles but cannot see how the rod is removed.
if you removed the handle from the rod you would need to put a pair of pliers on it gently and remove it. or if you turn it upside down and remove the tube from sliding mechanism you can grip the rod from there and unscrew
Mar 25, 2010 | Makita 10" Dual Slide Compound Miter Saw...
Makita LS1013 Sliding Compound Mitre saw will not lock at chosen positions/angles on the turnplate other than the standard stop points. Turning the handle will not lock the turnplate anymore, it used to,...
Mar 24, 2010 | Makita 10" Dual Bevel Sliding Compound...
Can't change mitre angle
you need to remove the guide fence with the screws on the back. then you remove the throat plate and there is the bolt is that keeps it all together.
Just took one apart last week, not really difficult
Dec 26, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
The vertical blade stop is not true vertical. What adjustments are there to adjust the stop?
If you look on the back of the saw where the pivot is, there should be a bolt on either side that should adjust how much bevel there is . As for a 90 degree angle, there should be a locking pin or stop to keep it from leaning out of square. Be sure that it is accepting the pin properly and that it is clean. Not sure if there is an adjustment on the sliding saw, but i know there wasn't on my dual compound mitre saw
Jul 26, 2009 | Makita 10" Dual Slide Compound Miter Saw...
I have a makita mitre saw and need to adjust the angle to 45 degrees. I unlock it and try to turn it but it won't turn. Any ideas?
you have to turn the handle, it works like a bolt, you cant see it but it is tied in, you have to unscrew it before trying to move it
Dec 13, 2008 | Makita 10" Dual Bevel Sliding Compound...
Makita 10" Dual Bevel Sliding Compound Miter Saw Logo
1,012 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
