Question about JVC UX-J50 CD Shelf System
CD Player not working
Cd being lifted into the playing position but not revolving.. Disc will turn quite freely
    President:
  • 1,851 Answers
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn’t solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 16, 2010
I have 5 disc changer that will revolve but wont play disc just keep running.
What you hear running may be a fan, a motor that spins the CD, the motor that moves the head in & out, or the motor that turns the turntable.
I suspect on something that old, the motor that spins the CD may be worn out. Place 1 CD in position and make note of the exact position of the words on the CD, let the player go through all 5 positions and see if the CD is still in the exact position that it was when you started. If this is the problem there's usually no easy way to fix it.
If the turntable doesn't turn, then it's that motor or a possibly a belt that no longer works.
There is also the possibility that the read head is no longer moving in and out smoothly, you'll have to take the unit apart and re-grease the slides with light lithium grease.
The read head being dirty or too dusty is another possibility, but even less likely. When you get it apart, clean the read head with a cotton swab and rubbing alcohol, anything harsher might damage the components.
Oct 08, 2016 | Sony CDP-CE375 5-Disc CD Changer
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
5disc multiple choice cds stuck in slots how do i
Have a look for a small hole in the front of the CD player - this is the emergency eject button. Find a paper clip, unwind it and then press the paper clip through the hole - the CD should then eject the first CD and you will then be able to eject the others.
Apr 28, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
My JVC cd player, plus Mini disc, and radio. CD will not play
Thank you for your email. The problem must have been dust. I kept putting the cleaning disc in for quite a number of times. Thankfully the problem was simple and it is playing super.
Kind regards to all.
Tonytopaz
Oct 12, 2009 | JVC Audio Players & Recorders
When I try to play a disc, the message
Hi there! Depending on when last the CD Player was serviced, I would think that the laser is at fault and needs replacement. However it may also be a mechanical fault. The only way to know for sure is to take the cover off and to see whether the disc turns at least a little bit before moving to the next. Also check whether the disc lifts into position properly and moves freely. If all the above proves OK, then the laser is probably at fault. Remember that there is current running through the unit so please stay away from any wires and boards when checking this. Best Wishes and Good Luck. JUS004
Aug 21, 2009 | Technics SL-MC400 110-Disc CD Changer
Cd player quit working
TRY LASER CLEANING DISC. FAILING THAT IT COULD BE THE LASER HAS DIED OR SERVO PROBLEMS.
Jun 19, 2009 | Emerson MS9825 CD Shelf System
TDK player reads CD disk but quits and does not play
your cd drive lens may be damage and lens preset will be not currect position so if you want to repair you cd drive then you have to turn your cd drive lens preset to currect position.
Dec 22, 2008 | TDK (ai-4800drombx-b) CD-RW/DVD-ROM...
Sony CD player C305 not playing
The laser or spin motor could be faulty.
Take it to a service centre for professional help.
John
Dec 15, 2007 | Sony CDP-CE375 5-Disc CD Changer
JVC UX-J50 CD Shelf System Logo
150 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
